Re: glow plugs
1/4" ratchet,Long extention and a Universal joint.Go between the chambers and feed the socket onto the glow plug.Best way to reinstall is take a GP and stick a piece of Rubber/Vinyl tubing over the connector and run it down then use the wrench/socket to tighten it.Much easier.Also,ONLY USE BERU/MOTORCRAFT GPS IN THE WHITE PLASTIC BAGGIES!
IDI Till I Die!!!
NCC-1701UAV U.S.S. Enterprise -1991 F350 CC dually.Lighted heated west coast mirrors,Nathan Airchime K3HA air horns,attitude from hell itself!
1994 F350 Crew Cab Dually,7.3 IDI turbo-Currently in the Roundhouse awaiting 10 year overhaul. White Lightning
1971 M35A2 deuce and a half.6wheel drive,Power Nothing!125 Horses in a 13,000lb truck.Real get up and go power! Martyr Machine
Cousteau 2006 Ranger STX-3.0 V6,5spd handshaker,standard cab
