Glow plugs not heating - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 03-21-2007, 06:26 PM Thread Starter
Hello, we have an ex uhaul 14ft truck, it has a 1990 7.3L non turbo.
The glow plugs are not heating up when you turn the key on.
What are some things we can look for besides the usual loose wires?
I'll pop in and out over the next few days to answer any ?s you may have or check out any suggestions.
Thank you,
Denise
feistywench is offline
post #2 of 18 (permalink) Old 03-21-2007, 06:34 PM
Re: Glow plugs not heating
search this forum, there are a ton of answers about GP. they probably, need to be replaced.
1993 Ford IDI 7.3L
F-250
ZF-5 speed 4 wheel drive
Class 5 hitch
D load tires <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
super cab
18x,xxx miles.
Purchased 9-22-06
luckys420 is offline
post #3 of 18 (permalink) Old 03-21-2007, 07:02 PM
First off, Welcome
Does the wait to start light come on, and if so for how long?
Does the volt meter drop and then cycle up and down?
Check the ground wire from the controller to the valve cover, make sure its tight and clean.
Test each glow plug with a test light or ohm meter. Replace only with Motorcraft/Beru ZD9.
1994 F250 7.3 IDI Factory turbo 5 speed Banks kit
9ENGEL is offline
post #4 of 18 (permalink) Old 03-21-2007, 09:07 PM Thread Starter
yes thank you I will be searching and reading
hubby is on the road and I need to find things a little quicker than I can read on the computer screen
Denise
post #5 of 18 (permalink) Old 03-21-2007, 09:14 PM Thread Starter
Thank you for the welcome.
Does the wait to start light come on, and if so for how long? Yes it does but then goes right back off, even when the engine is cold.
Does the volt meter drop and then cycle up and down? Not sure I will ask him next time I speak with him.
Check the ground wire from the controller to the valve cover, make sure its tight and clean. I am sure this is one of the first things he did, but will remind him to check and clean all wires.
Test each glow plug with a test light or ohm meter. Replace only with Motorcraft/Beru ZD9. I'll ask if he has his meter with him. Are these available other places beside a dealer? Not sure what is in the area where he is tonight.
Thank you for your input.
Denise
post #6 of 18 (permalink) Old 03-21-2007, 10:57 PM
arthurgoboom's Avatar
Autozone has the Motorcraft/Beru glowplugs. Good luck with that thing...diagnosing/repairing things on the road is such a pain.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Wellman G088 glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
post #7 of 18 (permalink) Old 03-21-2007, 11:12 PM
If the WTS light is staying on a very short time I would suspect one or more glow plugs are bad. Bad glow plugs trick the controller into thinking the plugs are hot and short cycling.
If he has anywhere to plug in the block heater for a few hours it should start without the glow plugs.
9ENGEL is offline
post #8 of 18 (permalink) Old 03-23-2007, 01:32 PM Thread Starter
Thank you, he is at an event for the remainder of the week and will hit an autozone Monday. Yes on the road is a pain for d/r but when that is where you make your living that is where you do it.
Thank you,
Denise
post #9 of 18 (permalink) Old 03-23-2007, 01:38 PM
Yes, You do what you must.
It sounds like the controller is working, or you would not be getting the wait light.
For $10 a piece, he might just wnat to change them all. Also make sure the connections are good and tight. Sounds like the tyical burnt out glow plug issues we have all been through.
If he gets a test light and hooks it to the positive battery lug. Then remove the wire and touch the plug, if it lights the plug is probably good, if not it is bad.
good luck. Where is he(city), maybe someone can stop by and help him?
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
DSBlack is offline
post #10 of 18 (permalink) Old 03-23-2007, 01:43 PM Thread Starter
Thank you, that pretty much confirms what one of the guys at the flying j was telling him. He can handle the repairs even to the point of a rebuild but diagnosing is a different story.
[img]/ubbthreads/images/graemlins/eek.gif[/img] we found out that the ford dealer that did the engine swap last summer cut the cord out, guess who I get to be on the phone with next week [img]/ubbthreads/images/graemlins/mad.gif[/img] fortunately we live in a warm climate
Thank you,
Denise
post #11 of 18 (permalink) Old 03-23-2007, 01:54 PM Thread Starter
That is what we figured on, going to have it opened up may as well do it all at once.
This week Waco, TX. He will do the work Monday then head on to LA.
Thank you,
Denise
post #12 of 18 (permalink) Old 03-23-2007, 04:29 PM
The cord to a normal block heater just plugs into the block heater above the starter. Pass. side. Do not know if the u-haul one is the same.
DSBlack is offline
post #13 of 18 (permalink) Old 03-23-2007, 04:41 PM
Denise,
Welcome to TDS [img]/ubbthreads/images/graemlins/smile.gif[/img]
When you get a chance, please fill in your truck and location info. Login, then go to "My Home" above, click on "Personal Info" and add your Ford truck details to your signiture and also your location and any other info that you want others to view.
Quick joke:
An expectant mother of twins was driving through town one day and got into a car accident. She was rushed to the local hospital where she delivered two healthy babies, a girl and a boy. Both mother and babies were fine. After the birth, the twins were taken to the nursery for routine tests. A short time later, the mother asked to see her babies so that she could get to know them and name them.
The doctor replies, "no need to name them, your bother has already done that for you.
The mother replies, "My brother? He is an idiot...what did he name them???"
Dr. "Well, the baby girl, he named Denise".
Mother "Oh, Denise...that is a really pretty name. What did he name the boy?"
Dr. "Well, for the baby boy, he named De-nephew".
Enjoy,
Hugh
1991 F250 XLT, 2WD, 7.3L IDI, 5 speed, 168K.
waterdude is offline
post #14 of 18 (permalink) Old 03-23-2007, 06:39 PM
cdnsarguy's Avatar
My Photos: (109)
You can buy a new cord.... or if the heater end is still attached with sufficient extra to scab in a bit of wire and a plug.
Read ... http://www.members.shaw.ca/k2pilot/ re GP removal.....
I sent you a PM (private message) re the GP controller test, click on the flashing envelope, if you got it......email me.
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #15 of 18 (permalink) Old 03-24-2007, 06:24 PM Thread Starter
Not sure what uhaul may have done with it, they did change a few things under the hood. Hubby found the heater cord underneath the back of his seat while looking for a loose socket. It was a bit of a surprise.
He'll wait till he gets home next month to fix that one.
Thank you,
Denise
