glow plugs not working - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 03-30-2012, 03:39 PM Thread Starter
tanbuddy's Avatar
My truck was starting fine untill a few days ago. THe plugs would come on for a few seconds, and then click on adn off for 30 seconds adn then the truck would start good.
Now i dont get any power to the plugs. I tested 1 bad one with my light, other than that all good.The wts comes on for 10 seconds like normal. IS that 1 gp throwing me off, or did the relay or controller take a crap? thanks
Work truck: 90 Pete 379, cat 3406B turned up
personal: Late 92 f 250 xlt ext cab 7.3 idi 4x4 5 speed(converted to f 350)
tanbuddy is offline
post #2 of 14 (permalink) Old 03-30-2012, 04:27 PM
chuckster57's Avatar
One bad GP can cause issues.
Sent from my Autoguide iPhone app
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 14 (permalink) Old 03-31-2012, 10:39 PM
wheatie's Avatar
Wink
Ditto, I had trouble once and found a bad plug connector. that was all it took to mess with the timer and make starting harder.
94 IDI Turbo 5 SPD Crew Cab, 287K, newer paint, 35 12.50 BFG, Big ARSS Stereo
2003 Excursion E.B. V-10,
2001 ZX3
2005 ZX4 ST Focus
2005 Escape
wheatie is offline
post #4 of 14 (permalink) Old 04-01-2012, 08:20 AM
My1strealtruck's Avatar
Make sure and use Motorcraft glow plugs. I do not remember the part number. These are the best for 7.3. I did a search for my online.
My1strealtruck is offline
post #5 of 14 (permalink) Old 04-02-2012, 06:33 PM Thread Starter
tanbuddy's Avatar
just got one today, im gonna throw it in later
tanbuddy is offline
post #6 of 14 (permalink) Old 04-03-2012, 06:11 PM Thread Starter
tanbuddy's Avatar
Put it in today, still not starting. The wait to start light works fine, but the big zig zag thing is not getting any power.
Im getting power all the time at the big lug catty carner to it.
The little lugs have power when the key is turned on, and it sound like the thing is clicks off after 2o seconds or so. Could the relay be bad on top of the controller? IS there a way to just test that thing itself?
thanks
tanbuddy is offline
post #7 of 14 (permalink) Old 04-04-2012, 06:40 PM Thread Starter
tanbuddy's Avatar
all the glow plugs tested good, and i got good connections. (tested wiht ohm meter from plugs connectors to the zig zag) any way to test the relay itself?
tanbuddy is offline
post #8 of 14 (permalink) Old 04-05-2012, 08:25 AM
shadowtrk's Avatar
Send a message via Yahoo to shadowtrk
relay
Sounds like the relay is bad or the solenoid on top of the relay is bad. you said it clicks but ur not getting power on the 2 big studs while its engaged?. if thats the case u can replace just the solenoid on top of the relay... im currently working on my truck doing the same thing.
92 Ford F-450 7.3 IDI.
SMF upgrade
alot of wireing left to do.
Pictures:
shadowtrk is offline
post #9 of 14 (permalink) Old 04-05-2012, 07:47 PM Thread Starter
tanbuddy's Avatar
New controller and still doenst work. the truck will start fine if i jump the 2 big lugs on the solenoid, or if i ground the little white wire. ALl the glowplugs are good adn are getting a connection.
Im ready to just toggle switch the ground on this stupid controller
tanbuddy is offline
post #10 of 14 (permalink) Old 04-06-2012, 09:13 PM
shadowtrk's Avatar
hmmz
Sounds like u have a ground issue. so the relay is clicking with the key?? but when it clicks the
2 big studs are not hot? still sounds like a ground issue. or a bad relay, but let me tell you they are tough i almost fired mine by not puting the little plastic cover on the relay and grounding it with the air cleaner lol. and it still works.
SMF upgrade
Pictures:
post #11 of 14 (permalink) Old 04-08-2012, 06:34 AM
Replace all of the plugs. I had the same problems. Also does the high idle kick in? Even when warm my wts stays on at least 5s. If you have power to the controller with the key on someting is telling not to work. The plugs or high idle.
post #12 of 14 (permalink) Old 04-08-2012, 05:42 PM Thread Starter
tanbuddy's Avatar
the big lug has power all the time, and the little lug has power when key is on, so that means all the fuses and fuse links are good right?
The ground is good, i checked that, ill check the high idle next.
the truck will start great if i jump a screwdriver accross the 2 big lugs, or if i ground the little stud with the rubber cap it works too.
the wait to start light stopped coming on as soon as i changed the controller to the new one.
tanbuddy is offline
post #13 of 14 (permalink) Old 04-09-2012, 03:52 PM
Put the old controller back in and see what happends. The WTS light should be working if the new controller is working. Even when mine plugs went bad my WTS still worked.
post #14 of 14 (permalink) Old 04-09-2012, 07:55 PM Thread Starter
tanbuddy's Avatar
will try that tomorrow. the high idle wire gets power when the truck is cold also
tanbuddy is offline
