glow plugs run for 15-20sec - Diesel Forum - TheDieselStop.com
Old 12-21-2008, 06:04 PM   #1 (permalink)
Cjhstang's Avatar
since i did my truck rebuild i've noticed the glow plugs running for upwards of 15 seconds. i don't have a wts light so i just wait until the voltage kicks higher indicating the gp's are off.
After it finally kicks off the truck will fire within 5 seconds of cranking. usually within the first full turn over if temps are above freezing. Ideas to why the gps are running so long?
7.3 IDI F-350 4x4 1990 150k miles
-Custom: '92 interior; '04 Hydroboost brake system; Volt/Temp/Oil Pressure/Oil temp/Trans temp/Boost/Pyro meters; Banks Sidewinder Turbo into 4" glasspack and dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump; Steering Box; Denso Starter
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-Dual 30micron to 2micron filter system... WMO WATF! Free Fuel!!
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
4.6l Mustang GT 1997 115K miles
GOTTA LOVE FORD MUSCLE
Cjhstang is offline
Old 12-21-2008, 06:22 PM   #2 (permalink)
chuckster57's Avatar
isn't 10-15 seconds normal. My WTS light will stay on for about 12 seconds and then the controller will cycle for a little bit longer.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline
Old 12-21-2008, 06:43 PM   #3 (permalink)
Snotzalot's Avatar
This time of the year for Pa your time is correct. You can crank once the relay starts cycling the GP's.
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger, 52,000 Miles
'90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak, Retired 11/8/2011 with blown trans.
7.3L Alternator Belt Idler Photos
Snotzalot is offline
Old 12-21-2008, 06:50 PM   #4 (permalink)
Mine do the same, 15-20 seconds from dead cold, even when engine is all warmed up they still glow for at least 5 sec.
M.L.S.C. is offline
Old 12-22-2008, 01:21 AM   #5 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Up here it's -25*F tonight, my GPs with engine plugged in all night will run 25 seconds in the AM......... and start on the second rotation.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 12-22-2008, 06:16 AM   #6 (permalink)
Snotzalot's Avatar
Pete have you ever considered moving to the Canadian portion of Miami for the winter???
Regards,
Old 12-22-2008, 09:07 AM   #7 (permalink)
cdnsarguy's Avatar
My Photos: (109)
I like the cold and know how to dress for it. Nothing more invigorating than sweeping a foot of fresh snow off the truck then running a snow blower for 2 hours in -20*F on a sunny day.
I tried the Vero Beach thing years ago (76-78).
Old 12-23-2008, 11:56 AM   #8 (permalink)
Bill1013's Avatar
For PETE sakes, pun intended, will you try and keep that cold up there, don't need it here in Ohio.
And Snotzalot, please keep the roads clear over your way, gotta go to Gilbert soon and pick up an engine.
Sorry about the hijack. Oh well a little humor.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline
Old 12-23-2008, 04:29 PM   #9 (permalink)
Snotzalot's Avatar
Clear roads in Pennsylvania, you have got to be kidding!
Regards,
