Old 12-10-2005, 06:28 PM   #1 (permalink)
got a dead miss and a little tick
I have recently devloped a miss, it puffs smoke, not continually. There is a tick up high. coolant level is the same as it was. I hope its a rocker arm problem and not cavitation. i cannot tell which bank its coming from. where do I start on this?
89 250, 4x4 chromespoke wheels, 270000k, 4.10 gears with rear LS. stock everything else. Its loud, and smokes, but its paid for!
sawyer89 is offline
Old 12-10-2005, 06:45 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: got a dead miss and a little tick
Gently open (crack 1/2 turn) each injector then close it. The injector that does not make a difference in performance at idle would be suspect. Try that and post back........cover the injector with a rag "High pressure".
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 12-10-2005, 07:00 PM   #3 (permalink)
Just went thru the same thing.....dead miss and tick with blue/gray smoke intermittenly......my problem was a hung injector causing the dead miss....truck shook like crazy at low speed.... Sounded like a loose rocker arm pecking! Anyway, I ended up having some major injector problems and had them all replaced......I cant tell you what a difference it made in performance and now I have no shake! Smooth running. And...no smoke!
93 7.3idi f-350 dually crew cab 2wd factory stock
4.10 gear 5 speed.
twoodrum is offline
Old 12-10-2005, 07:02 PM   #4 (permalink)
Crack injector lines one at a time while it is running and find out which hole it is.If you find a bad one swap that injector with another on the other side and see if the noise followed it.If it did you got a bad injector.If it doesn't go away as you break the lines loose then take a stethiscope and listen to each bank and see what side it is coming from.Pull that valve cover.If it stops but doesn't follow the injector also pull the valve cover.Make sure nothing is loose or that a push rod didn't go though the rocker.If all is fine,check to see if you can rock a valve back and forth to make sure the guides are ok.
IDI Till I Die!!!
NCC-1701UAV U.S.S. Enterprise -1991 F350 CC dually.Lighted heated west coast mirrors,Nathan Airchime K3HA air horns,attitude from hell itself!
1994 F350 Crew Cab Dually,7.3 IDI turbo-Currently in the Roundhouse awaiting 10 year overhaul. White Lightning
1971 M35A2 deuce and a half.6wheel drive,Power Nothing!125 Horses in a 13,000lb truck.Real get up and go power! Martyr Machine
Cousteau 2006 Ranger STX-3.0 V6,5spd handshaker,standard cab
m35a2 is offline
