Old 03-23-2005, 07:56 AM   #1 (permalink)
Got my T-case fixed! Now, question about oil pressure sender..
YEE HAW! Finished up putting in my boneyard 1356 t-case last night at about 9pm. Went ahead and put new u-joints in the front driveshaft while I was at it. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] I'll have to post some pics of the truck "after stacks". Don't think I have one up yet.
Truck seems to pull a little better. [img]/ubbthreads/images/graemlins/shrug.gif[/img] I think maybe there was a LOT of drag in the old T-case towards it's latter days. Pump locked up on the mainshaft, sent most of the pump into the chain and broke a shift fork. Don't know if racing the 12V cummins had anyhting to do with it or not 2 days previous to it going out. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
NOW,
I'm tired of the "Turbocator" Hypermax boost/pyro all in one thingy, so I'm going to order some new ISSPROs today. Adding an oil pressure gauge and need to know where an alternate location for the sending unit would be besides the pressurized outlet providing oil to the turbo. I think the factory sending unit is back there, and it's a mo-sucka to gain access to.
Is there another port on the side of the block somewhere?
Oh yeah, if anyone wants this turbocator thingie, let me know, It won't come with the tubing kit or a thermocouple, but since I'm a dealer for ISSPRO now, I can get that stuff for ya cheap. [img]/ubbthreads/images/graemlins/smokin.gif[/img] It will come with the housing, painted to match the maroon ford interior.
New rig: 1995 Dodge 2500 LB, Reg. Cab, 4x4, Cummins, 3k GSK, Hillbilly plate ground, 4" exhaust, 285/75/16s
Old rig:
1989 F-250 7.3 IDI, 4x4, 4" Rough Country Lift, Hypermax Turbo, 128K, 5 Speed, 4.10 gears, Custom air intake, "MIG-Made" Propane Kit, 3.5" Dual Chrome Stacks w/ straight exhaust, 285/75/16 tires on Classic 589s, Pioneer MP3 Player with 10" sub, Galaxy DX959 CB. Savin' some bread for some new 315/75 shoes.
My drinking team has a rockcrawling problem.
Hold it 'til the valves float!
nosliw is offline
Old 03-23-2005, 10:52 AM   #2 (permalink)
Re: Got my T-case fixed! Now, question about oil pressure sender..
I think there is a port on the oil filter housing.
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
Old 03-23-2005, 01:10 PM   #3 (permalink)
d9d
as I recall, there was some discussion here, a year or so ago, about there being different pressures at the different ports; due to distribution losses in the engine.
Can't remember what the upshot of the whole thing was; but maybe that moving the gauge would give one a reading that wouldn't correlate well to the factory spec or other people's readings.
...but I sure wouldn't want to go after that factory sender with a full turbo kit on either! [img]/ubbthreads/images/graemlins/grin.gif[/img]
My Rig: 1991 F350, 4x4, 5-spd, 7.3na, 4.10 solids, std. cab, flaking factory blue... [img]/ubbthreads/images/graemlins/grin.gif[/img]
My other diesel is a...
Hydra 35-ton Excavator, 6V71T; Isuzu C201 genset;
'71 VanPelt Pumper, Cummins 855 Turbo
There used to be a link here, to some useful IDI-diesel tech info; but it was chopped out by others, in a vain attempt to repress the very essence of the internet: linking!
sigh...
d9d is offline
Old 03-23-2005, 02:50 PM   #4 (permalink)
your correct the oil filter housing port will give you a higher pressure, also guys like to use the turbo supply port because then they know there getting enough oil through the turbo.
Allen
Old 03-23-2005, 02:57 PM   #5 (permalink)
My Photos: (24)
i'm also interested to know a location to install this oil pressure circuit i have. i just need it to know when the oil pressure is above 10psi so it will allow power to go trought (a safety circuit). i the one behind the gp comptroler the best to use or i can get it out of the bottom of the engine on on the filter hosing?
exekiel
- 12/92 f350 jasper 7.3L 17k Torito
- Home made exekiel propane system, sweet
- Home made ram-air system
- 4.10 open, DRW
- zf5 trans (dextron and militec); 12" luk solid fly wheel and clutch set.
- exekiel coolant filter system (Fleet-guard filter and dca)
- ip runing with stanadyne every tank and Mels timed.
- Agnem manual tranns starting system :-)
- Hypermax turbocharger system YES Finally. Turned up a la Travis.
crew cab/ wood interiors/ 800w cd player. Sweet ;-)
2 new diamond headlights
4 100w flash lights and 2 withe fog lights
more pics
BOOB Man
soon..
- paint job.
exekiel69 is offline
Old 03-23-2005, 03:00 PM   #6 (permalink)
I plumbed mine in on the turbo supply, same location as the factory sender now. I see pressures of 10-13 psi at idle and 35-45 while running. I am sure these are low compared to the block but I know that the turbo is getting oil. My stock gauge stays on the L no matter what the mechanical says. So much for the stock setup.
1993 F-250 XLT 4X4 7.3 nat asp. Banks turbo installed 02/13/05, straight piped, 5 speed, 4.10 gears 235/85R16 stock wheels
1990 F-150 4X4 302 5 speed
1976 CJ7 4X4 258 3 speed
1995 Grand Cherokee 4x4 4.0 litre
1990 K-2500 GMC 4X4 350 Auto
1979 F-150 4x2 300/6 4speed 4bbl dual headers/exhaust
1986 Vacationeer 23' Fifth Wheel
2005 Gooseneck(brand) 4 horse gooseneck stock trailer
1941 Allis Chalmers C Ser# C541
1948 Allis Chalmers C wide front
ARIZHNT is offline
