Old 07-19-2007, 01:08 AM   #1 (permalink)
My Photos: (9)
Gotta say goodbye (for a whle).
Guys (and Gals),
Its been real and its been fun and its been real fun (and informative). [img]/ubbthreads/images/graemlins/smile.gif[/img]
To all that freely shared their knowledge (and opinions), thank you. [img]/ubbthreads/images/graemlins/smirk.gif[/img]
For me its back to the sandbox on 1 Aug. [img]/ubbthreads/images/graemlins/frown.gif[/img] My younger brother will be utilizing Big Red while I'm gone [img]/ubbthreads/images/graemlins/shocked.gif[/img] (now you know why I didn't turn up the fuelpump or wastegate rod). He promises not to tinker until I get back. Should be back somewhere between 14-24 months from now.
I'll try and persuade him to sign on here and get help (yes he needs a lot of help - mentally [img]/ubbthreads/images/graemlins/biggrin.gif[/img], psychologically [img]/ubbthreads/images/graemlins/eek.gif[/img], co-ordinationally [img]/ubbthreads/images/graemlins/grin.gif[/img] and with his love life also [img]/ubbthreads/images/graemlins/blush.gif[/img] - he he he, what are older brothers for anyway [img]/ubbthreads/images/graemlins/cool.gif[/img] ?).
Once again folks thanks for everything and when I'm back maybe I can get those *($&^#% axles swapped.
94 F250HD Ext Cab XLT 4x4
Ford Factory IDI Turbo diesel
ATS Outlet/Downpipe upgrade with 4" exhaust system
ATS step 1 upgraded E4OD
Sterling (Ford)10.25 4.10 R-diff,
Dana 50 4.10 F-diff
ISSPRO EV Pyro, Boost & Tranny temp gauges
Pillar Mount
[color:"blue"]MY PICTURES[/color]
sojerguy is offline
Old 07-19-2007, 01:14 AM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Gotta say goodbye (for a whle).
Take care.........I'll put you in my thoughts along with our CDN lads and lasses in Afganistan........
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 07-19-2007, 10:30 AM   #3 (permalink)
Thank you, And you will be in our prayers. Ny nephew is headed over soon also.
1990 F-350 Dually 4X4 CC Rebuilt Turbo and NEW 7.3L DAS engine, rebuilt rear diff, Reman E4OD Stage 1 injectors Stage 1 pump Baumann recal kit and TDC for E4OD dead trans again...
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
DSBlack is offline
Old 07-19-2007, 12:41 PM   #4 (permalink)
Thank you.... Its a job I wish I could do but can't.... I'm too old now.... Just saying thank you seems like its not enough. I know when you get back there will be a get together. We will keep you in our thoughts for as long as it takes to return home. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
icanfixall is offline
Old 07-19-2007, 02:39 PM   #5 (permalink)
Godspeed, fella. Thanks for your service- we're praying for your safe return.
Keith
93 F350 CC Dually 7.3 Hypermax turbo 4:10 gears, ZF rower, K&N filter, home made ram-air, Hypermax 3.5" exhaust, LUK clutch, 150,000 mi.
Weezer is offline
Old 07-19-2007, 06:57 PM   #6 (permalink)
go kick some W@#E%R@#$#@$# AZZ...
Im no Einstein...but I might be a Rocket Scientist !
2001 F-350 2X4 Supercab longbed 7.3. 5" Bull Hauler stacks
1998 Dodge 2500 2X4 5.9 cummins racer
2006 Dodge 2500 4 Door 4X4 CTD
Lee Haenschen is offline
Old 07-20-2007, 09:30 AM   #7 (permalink)
My Photos: (23)
We're praying for you and all our heros over there! Check in when you can.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 07-20-2007, 04:44 PM   #8 (permalink)
As Patton said, hold 'em by the nose and kick them in the pants! Good luck and thanks for your service!
Phillip
A.K.A. Sign_man
1988 F-Superduty bucket truck, 7.3 IDI, LuK Clutch, 5 spd, 4.10 rear
http://photos.thedieselstop.com/show...=70062&thumb=1
Phillipmc1268 is offline
Old 07-21-2007, 01:30 PM   #9 (permalink)
keep your head down & dont come back with an "I forgot to duck medal"
97 dodge 2500 4x4 cc lb 12V auto 3.54 pillar gauges 215 nozzels
31'TT at 8000 lbs
94 explorer
shorthair is offline
Old 08-29-2007, 10:13 AM   #10 (permalink)
My Photos: (9)
All,
Been here about a month, and its just as much fun as last time. Still the life of a GD contractor is so much better than that of all the troops that go outside the fence.
I do what I can to make sure they have what they need to come back in one piece.
Taji is relatively quiet, (had a few rockets two weeks back), but other than a destroy'd sleeping hootch none of guys got hurt.
Heat, some dust, more heat, occasional fly, more heat ... get the picture. In a month or so, it'll be getting (somewhat) cooler, and then 1-2 months after that (a bit) rainy.
Well that's the news for now.
Keep the (black) smoke flowing.
Dana 50 4.10 F-diff
Pillar Mount
sojerguy is offline
Old 08-30-2007, 10:23 AM   #11 (permalink)
My Photos: (23)
Thanks for checking in! God bless.
- Mel
agnem is offline
Old 08-30-2007, 04:09 PM   #12 (permalink)
asauer's Avatar
Send a message via MSN to asauer Send a message via Skype™ to asauer
If you're ever in Balad look me up. I'll be here for a few more months...
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
Member of Indiana Air National Guard 122FW MXS
asauer is offline
