Old 09-02-2005, 11:11 PM   #1 (permalink)
greyish smoke?
Still working on the 89 F-350 that a lot of you have helped me with but have a few more bugs to stomp! By replacing # 8 valves, push rods, hydraulic lifters I have solved the skip on # 8.
When I put everything together and tried to crank the truck it would start up for a couple of seconds every time I tried and then shut off.
Finally took return line loose and truck ran fine. Traced the problem to the # 4 injector which I somehow must have clogged accidentaly. Replaced and seems to have fixed.
Next bug is when truck was purchased it smoked greyish smoke like a mosquito sprayer while going down the road and If I remember some at idle also. Now the truck doesnt smoke at idle but when I took for road test it showed up. I could compete with any mosquito truck.
While on road test I made it about 1/2 mile and truck shut off. I believe it ran out of fuel so I retrieved some fuel and bled schrader valve and cranked again. Made it back to shop fine and then, shut it off and cranked a few times and everything seemed o.k. so tonight my belief is just ran out of fuel.
Tomorrow I plan to do some more road testing but I do know that once I crank and bring up the R.P.M.s that the greyish smoke boils out.
Any body got any Insight as to where the poblem lies. I have posted several times the last couple of weeks and the old post show some of the specifics obout this engine and the problems associated with it. [img]/ubbthreads/images/graemlins/confused.gif[/img]
1989 F-250 4x4 C-6 7.3
1991 F-250 4x4 E-4OD 7.3
1989 F-350 4x4 5 speed manuel 7.3 (present project truck)
1989 F-350 4x4 E-4OD 7.3 (4 door) (future project)
John deere 450C Crawler
Ford 6610 4x4 Tractor
Diamond Rio Dump Truck
Chevy Dump Truck
International Semi
remote is offline
Old 09-02-2005, 11:16 PM   #2 (permalink)
Re: greyish smoke?
Sounds like you have a timing problem my friend. Needs to be set with a meter to be perfectly accurate. 1.5* ATDC @ 1400 RPM with the luminosity method or 8.5* BTDC @ 2000 RPM with the pulse method. If you know you fixed the engine, it's probably the timing or possibly injectors/pump, but I would check timing first. Also bear in mind if you get air in the system it will act funny and blow smoke too.
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
