Old 12-19-2005, 01:57 PM   #1 (permalink)
group 31 batteries in '92 truck?
Anybody fit some 31's under the hood? I had some in my '86 no problem. I can get Interstate 950cca 190rc for $33/each. But this truck uses the bottom clamp hold down and the grp 31's I can get are bigger (obviously) and don't have the feet. I am not too worried about the hold down..mostly if they fit in the tray...etc.
86 F250 4x4 Ex-cab, 6.9 w/vintage Banks Turbo/Exhaust, T-19, 3.55L?, XLT, push button propane on stick, GV ilo transfer case.
(Lizard Limo) 92 F350 CC 4x4 ZF5 Banks Turbo...straight piped (muffler rotted off)...6.9 installed during 7.3 rebuild.
jrfastbanshee is offline
Old 12-19-2005, 05:14 PM   #2 (permalink)
Re: group 31 batteries in '92 truck?
I've been running them in mine for over 3 years now-post type, the stud type with adaptors are too tall. They just barely fit into the trays, and I had to move the harness of the left side a little, use top mount hold downs and j-hooks but they work great.
1993 F-250 XLT 4X4 7.3 nat asp. Banks turbo installed 02/13/05, straight piped, 5 speed, 4.10 gears 235/85R16 stock wheels
1990 F-150 4X4 302 5 speed
1976 CJ7 4X4 258 3 speed
1995 Grand Cherokee 4x4 4.0 litre
1990 K-2500 GMC 4X4 350 Auto
1979 F-150 4x2 300/6 4speed 4bbl dual headers/exhaust
1986 Vacationeer 23' Fifth Wheel
2005 Gooseneck(brand) 4 horse gooseneck stock trailer
1941 Allis Chalmers C Ser# C541
1948 Allis Chalmers C wide front
ARIZHNT is offline
Old 12-20-2005, 05:56 AM   #3 (permalink)
My Photos: (33)
My S sieres uses them but I got taken, $92. each from the tractor shop ouch. 1000 cca
95" Extd Cab F250HD 4x4 DRW, /86"6.9 T19 GV o/d 3.73 axles, Hypermax Pulse turbo, intercooled / Modified Hypermax ram air induction, PowerShot 2000 LPG system "first design". Ride rites @ all 4 corners, Dana 50 mono Beam up front, Ford 10.5" in rear with 4 wheel disk brakes. Other Truck, 1983 IHC "S" with 14ton NoMar wrecker body, 30,000 GVW, 229"wb with a 6.9L IDI, Clark 5sp, 5.57 rinp&pinion, turbo charged and intercooled (with LPG soon).
Huff is offline
Old 12-20-2005, 10:49 AM   #4 (permalink)
My Photos: (17)
Huff, if you think you got 'ouched', In Baja I paid $150.00 each for my Exide AGMs(1000ca). I did soo much business with them that they gave me 'credit' and I paid them $100/mo for 3 months. I don't know their cca rating, but, I really like no terminal corrosion and never need to add water. They seem to be handling this cold weather here. OkieGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 12-21-2005, 12:49 AM   #5 (permalink)
I'll let you know how mine fit in a couple of days. I just picked up a pair of 31s stud top 1125ca, 1000cca 185 res for $63 ea at Truck Pro
Now to squeeze them in. Looks like they'll fit no problem, but I am going to put a sheet of rubber over top of the connections for safety , I sure wouldn't want that much juice arcing off the hood on a bump :-)
I've got a day of battery mountng/cable making/starter mounting commming up.
------Robert
'92 F-350 7.3 5 spd, Crew Cab dually,ATS turbo, 4" Exhaust, Air seat, Western Hauler bed. My Gallery
RLDSL is offline
Old 12-21-2005, 06:50 PM   #6 (permalink)
Well, I had time to put one of the new group 31s' in my ;92 f350 today on the passenger side. I had to move the battery tray about 1/4" inboard to clear the wire harness that goes behind it.I also had to cut off the exposed bolt end for a ground wire that was poking into the battery.
I stacked 3 washers to space it out from the wall, and I still had to shoehorn the battery into the tray.There will be plenty of clearance for the positive terminal with it on the inboard side, the outboard ground terminal will be mighty close to the hood, but that won't hurt anything. It looks like I'll have to move the tray on the drivers side as well.
------------Robert
RLDSL is offline
Old 12-24-2005, 01:40 PM   #7 (permalink)
Well I got around to putting the drivers side battery in, it was an even tighter fit. I had to space the tray a little further out from the wall and shoehorn the battery in, but they're in now and with 1125 ca each that thing spins like a maniac. start up is almost instant now when cold.I made up a full set of 3/0 cables for the stud top batteries and 6ga for the tie in hot and ground wires. Along with new starter glow plugs and controller I should be good for quite a while.
RLDSL is offline
Old 12-24-2005, 07:22 PM   #8 (permalink)
I was tired of dual, dead, leaking, rust machines, in the front of my truck pounding my radiator support to death, cracked all over, so I ditched the factory mounting location and mounted one $311 oddessey
PC2150 group 31 battery. I didnt buy it here wish I did now http://www.batterystore.com/Odyssey/PC2150.htm
I used 2/0 cable from the battery to the starter and 1/0 to the solonoid. used a 2/0 ground to the frame, and the battery was hung under the bed on the pass side behind the cab.
truck starts every time no more crank and no start, even at temps as low as 30 degrees it cranks right up, let me say it does crank about 5 seconds then fires, being in florida I have disconnected my pesky glow plug system 5 years ago, still fires up no hassles.
hope this can help, I am very pleased with this battery.
Javier [img]/ubbthreads/images/graemlins/smokin.gif[/img]
1987 F250 dually 7.3 banks sidewinder C-6 GV overdrive 3.55 lots of factory eliminated mods
i/e rear hung single battery, re engineered fuel system, no more tank switch, electric holley blue pump, return style regulator, #8 fuel line feed and return, both tanks, Amsoil 5w30HDD with full flow / bypass filters, Amsoil of course.
Evans coolant and Amsoil conical air filter. last oil drain 2003 65k ago. I add about 8qt per year with filter change. rear main likes to leak parked only.
IDIABUSE is offline
Old 12-24-2005, 10:59 PM   #9 (permalink)
Any way you can send me a few pics of how you mounted the battery to me at 60bugeye@cebridge.net. Sounds like something I am very interested in doing.
Leo
1994 Ford F-350 CC with 105K. Slowly plugging away at achieving mechanical nirvania and a turbo with bigger exhaust system.
1960 Austin Healey Bugeye.. TOTALLY restored to stock configuration and NEW condition My baby
60bugeye is offline
Old 12-25-2005, 04:16 PM   #10 (permalink)
pics sent hope they help you decide how to mount up a battery.
Javier
IDIABUSE is offline
