Hard Brake Pedal - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 03-06-2006, 08:13 AM Thread Starter
Hard Brake Pedal
Yesterday just out of the blue when I went to hit my brakes, the pedal was very hard. This has never happened before. Can anyone tell me where I need to start to check out this problem? I got out and pulled the vacuum hose off the booster and a friend held the hose while I cranked the engine. No vacuum. After I throttled the engine the vacuum came up? Any suggestions would be greatly welcomed.
1993 4x4 F250 XLT 7.3 IDI Diesel E4OD trans. 4.10 gearing. 170,000 miles and still going. Works every day without complaints.
coleyslawn is offline
post #2 of 17 (permalink) Old 03-06-2006, 11:23 AM
Re: Hard Brake Pedal
Unless you sprung a leak in the vacum hose the vacum pump is bad. These pumps are not extremely long lived if they are new and even less if rebuilt.
'06 F250 Crewcab King Ranch 4X4 auto Black 6.0 stolen 12/31/14
by clifford bledsoe.
'09 Cameo 5thwheel home while working
'02 Eddie Expedition
'91 F250 SuperCab 4X4 Stock IDI 2 tone brown E4OD
'96 IH 7.3 4700LP field mechanic
'84 Bronco II 2.8 4 speed 4X4
'50 F-1 V8 Flathead 4-speed non syncro(bought new)
'76 Honda 250 Multi Sport(enduro)
'76 F250 4x4 standard 360 Highboy
mont91 is offline
post #3 of 17 (permalink) Old 03-06-2006, 12:59 PM
cdnsarguy's Avatar
My Photos: (109)
Do the vacuum test on my gallery......
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #4 of 17 (permalink) Old 03-06-2006, 06:56 PM
Most likely the vacuum pump.
The pulley removal / installation is important. Pulley comes off with a power steering pulley remover.
DO NOT reinstall the pulley by pounding it on with a hammer. A certain un-named half man / half robot did that and ruined a perfectly good pump.
To install pulley, it should be pulled onto the shaft with the hole in the middle of it. Get a metric threaded bolt, nut and a few washers (8mm I think, I just walked the darn thing into Home Depot and matched it). Find one with plenty of thread, then cut off the unthreaded part. Thread the stud all the way into the shaft hole, put the washers on, then run the nut down on top of the washers with an impact wrench until the pulley is all the way on.
You can also use a plain bolt and washers, but it's more work because you have to keep puting more washers under till the pulley is all the way on and you risk stripping the shaft hole threads.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #5 of 17 (permalink) Old 03-08-2006, 02:33 AM
My Photos: (10)
When that happens, watch for your emergency brake light. It may be coming on letting you know that your pump is going bad / vacuum leak somewhere. I would do the check soon. My pump failed when coming off of a freeway off ramp. That was exciting [img]/ubbthreads/images/graemlins/shocked.gif[/img]
92 F350 XLT Crewcab dually, 225K miles ATS turbo, 4 inch exhaust, fresh IP & new matched BB injectors, Holly Red pump, K&N, E40D, 2 aux coolers, A-pillar guages, 410 limited-slip rear, Rancho 9000s, towing package, full running boards, mud flaps, 94' Ford (Alcoa) aluminum wheels, Predator camper shell, 600 watts of Sony/Boston Acoustics! Complete engine rebuild at 176k miles. Ford reman E4OD at 204k miles.
2001 Komfort 26FS
Fozz is offline
post #6 of 17 (permalink) Old 03-08-2006, 07:30 AM
last summer i had a broken vacuum pump along with bad brake booster/internal rabs leak. it was fun trying to drive, one second you would have to stand on the pedal to stop and the next it was all the way to the floor. [img]/ubbthreads/images/graemlins/blush.gif[/img]
my trucks: 1989 F-250 custom 7.3L idi, regular cab, 5 speed ZF-5 tranny, 4x4, blue w/ blue interior, 229,xxx miles, bronco buckets, 4" custom exhaust, luk smf;
1987 ranger pick-up, 2.9L, 5 speed manual tranny, 2wd, extended cab, red w/ red interior, 178,xxx miles; gone
1990 f-150 xlt lariat 4.9L, regular cab, automatic, 2wd blue/grey w/ grey interior, 169,xxx miles
1987rangerpu is offline
post #7 of 17 (permalink) Old 03-08-2006, 08:20 AM
I belive Napa auto parts sells the kit, its from KD tools and has bacome very handy doing steering and vacuum pumps, save a ton of work especially when installing the pulley on the new pump. I think its around 90 dollars and it worth every bit of it.
3 X 06 Ford F250s 6.0 stock 4X4, just got two more, so now 5!
2003 Ford F250 4" Lift, Chipped, 4X4, Diamond Box
2000 Ford F250 7.3 PSD, 4X4, Stock
1999 Ford F350 7.3 PSD, SRW, 4X4, Chipped
1994 Ford F250 7.3 IDIT, 4X4, Pump cranked way up, fuel milage down way low, 6 inch lift on 315/75r16, still rides like a caddy for its day.
And I grow asparagus.
cwatanabe is offline
post #8 of 17 (permalink) Old 03-08-2006, 08:53 AM
Any news? Check the tension on the belt and belt condition too. I replaced my vacuum pump last year after the same symptoms.
Buy or borrow a vacuum guage and do the vacuum dianostic procedure. Measure the vacuum after it is repaired to know your new baseline.
--Hugh
1991 F250 XLT, 2WD, 7.3L IDI, 5 speed, 168K.
waterdude is offline
post #9 of 17 (permalink) Old 03-09-2006, 07:05 AM Thread Starter
Hello everyone,
Sorry for the delayed response. I am a landscaper by trade and I have been extremely busy. I did do the vacuum test that was suggested and here is what I came up with: Test 1 I checked the vacuum pump and it read 22Hg on the gauge. Test 2 I hooked the gauge up and I got a reading of 18Hg and when I pressed the brake pedal, it dropped to 10hg and slowly crept back up to 18 after releasing the pedal.
I dont really know any more now than when I started becouse I have been driving it and the problem has not occured since. Does anyone know where to go from here? According to the test It says replace the booster but I want to make sure before I just start replacing parts. I priced a new vaccum pump at Advance Auto and it will set me back 268.00 Lord only knows what a booster would be. Any help would be appreciated. Thanks for all the replys.
Jr
post #10 of 17 (permalink) Old 03-09-2006, 10:41 AM
Just recently replaced the booster on my 89 250 and it was about $60 - $80 at Auto zone.
89 F250, 7.3 IDI n/a, overhauled E4OD with upgrades & billet torque converter 12/05, 3.55, all sensors replaced, 15k High volume low resistance tranny cooler. Alternator mod. Headlight mod.
datkinsonsr is offline
post #11 of 17 (permalink) Old 03-09-2006, 11:35 AM
cdnsarguy's Avatar
My Photos: (109)
I think you deserve a visit to....... the Shop diesel web page for your next NEW vacuum pump.
post #12 of 17 (permalink) Old 03-09-2006, 12:50 PM
The link above is a better price than I got for $130. You will reuse your old mounting bracket and vacuum pulley. Was that price you quoted for just the pump? or installation too?
Your brakes failed once, so they are bound to fail again in the future.
Lots of helpful info by searching vacuum pump in the search function for 7.3L (non-powerstokes).
--Hugh
post #13 of 17 (permalink) Old 03-09-2006, 09:56 PM Thread Starter
Thanks for the link cdnsarguy, that is a far better price. Hugh the 268.00 is the price that Advance gave and I will have to install it myself. I guess for peace of mind, I will go ahead and get a vacuum pump and put it on. This is a great place for advice and I appreciate everyones help. Thanks
post #14 of 17 (permalink) Old 03-14-2006, 08:25 PM Thread Starter
Well since the last post everything has been fine until tonight. As I was turning in the driveway, the pedal got hard again. I have noticed that the last time it done it and this time that the hard pedal occured when I let off the accelarator. Is it the vaccum pump or the booster? Any info is appreciated. Thanks
post #15 of 17 (permalink) Old 03-14-2006, 09:23 PM
cdnsarguy's Avatar
My Photos: (109)
Well if you decellerated to turn then engine would be at curb idle, if you used the brakes then the vacuum would be depleted. At curb idle the vacuum pump is slow to recover but there is a minimum time on the test I believe.
