Old 08-04-2008, 12:57 PM   #1 (permalink)
Hard start after fuel filter change
After changing my fuel filter, my '90 F-250 has developed a hot hard starting problem after sitting for an hour or more. When I changed the filter, it took a lot of cranking to bleed. Now, when it's been sitting for an hour or more, it spins as if it has no fuel, but, for now, will start after 3 or 4 cranking periods of 10 seconds or so. Before changing the filter, it started anytime, no matter the temperature. The truck has 330K miles on the original injection pump, so I'm guessing that's the problem from reading other posts, and I have not tried pouring water on the IP as recommended in other posts. Operation of the fuel shutoff has been verified. I'm not opposed to rebuilding/replacing the pump, but I was hoping someone would be able to explain why the problem appeared after changing the fuel filter.
Thanks,
Jason
Alexandria, La.
jlm033 is offline
Old 08-04-2008, 01:04 PM   #2 (permalink)
Sounds like you need to check your return line hoses now. Just a guess here... but you probably knocked one loose or forgot to put one back one. So now every time you shut your engine off the fuel filter drains out a bit making your engine have to reprime it every time you want to start. It's happend to me before... Look for any fuel leaking anywhere and possibly dripping off the bottom of the engine.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 08-04-2008, 01:38 PM   #3 (permalink)
dakotajeep's Avatar
What yaric said.....the same thing happened to me. I thought I connected all the lines on the rear sending unit but had one that didnt fully/properly connect.
1994 F350 XL Crewcab 4x4 SRW 7.3 NA
Dana 60 Sterling 10.25 3.55 285/75 16 Dayton Timberlines
TC lockup Mod
Pyro Installed!!!
TO DO: Boost guage, Tekonsha Voyager Brake controller and Turbo when I acquire one!!!
A little rough but its a truck not a show car!!!
PICS of my rigs and random stuff: http://s230.photobucket.com/albums/ee67/dakotajeep/
dakotajeep is offline
Old 08-05-2008, 07:18 AM   #4 (permalink)
I checked the return hoses and no problem there. Wouldn't the return hoses cause the hard start problem no matter the engine temp? It can sit overnight and start like normal, but starts hard after it's been shut off for 1-4 hours.
Thanks,
Jason
jlm033 is offline
Old 08-06-2008, 03:38 PM   #5 (permalink)
danngreen's Avatar
jlm, are you getting pressure out of the schraeder valve on the filter?
My first project truck: '90 F250 7.3L IDI 2WD, camper shell, primed and ready to pick color(s). Dual exhaust pipes (stainless) L-O-U-D (gotta get mufflers). Rest is stock, AFAIK
WORK DONE: replaced starter, new return lines/injector-caps, new glow plugs/wiring harness/controller-relay, replaced fuel filter
IN PROGRESS: SVO conversion (installing parts)
danngreen is offline
Old 08-07-2008, 12:17 PM   #6 (permalink)
Yes, I'm getting pressure from the schraeder as soon as it starts to spin.
jlm033 is offline
Old 08-08-2008, 07:50 AM   #7 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Check the filter air leak areas for wetness.......
http://www.intellidog.com/dieselmann/filter.jpg
Proud Canadian BOOB man too!!
cdnsarguy is offline
