Engine turns over for a long time before it finally starts, white smoke comes out of the tail pipe. Once it has ran for a while, the engine starts normal for the rest of the day.
Fuel filter was changed @ 118,000.
How often should I change the fuel filter?
What type of fuel additive should I use?
Thanks for all the info. I get a lot of info from this forum.
1992 F-250XLT 7.3L IDI Banks Stinger exhaust system
Im not 100% sure on the interval, but I'm sure @ 23k mi, that fuel filter isn't helping the situation. If that doesn't help, check the glow plugs... tis the season =D! And don't rule out a possible air leak into the fuel system, mines kinda notorious for those...
__________________ '88 F250 XLT Lariat Supercab ALO,T!!mi., C6 Auto, 3.55 rear, 16" Aluminum Summit Racing Rims, Bridgestone Duelers, Holley Red fuel pump mod,Clairion reciever & component speakers, Kicker 10" powered sub, fresh IP, injectors, brake shoes, & Shiny new headlights...Lovingly named "Brownie" simply because its brown and a sweet ride .
I eyeballed the fuel lines from the lift pump up to the filter, but didn't see any signs of leakage. I guess the fuel filter would be a good start huh? The filter looks like an oil filter, does it come off similar to?
Should I be concerned about fuel spillage?
Whats a good way to check the glow plugs? I have mechanical skills and understand the use of and ohm meter.
I bought the trunk this summer, and it's my first diesel, so I'm still learning the ins and outs of the diesel engine.
thanks
Yup, fuel filter is easy, same idea as an oil filter, except you'll wanna fill it up with fuel before you install it. As for spillage, there's not alot, just be sure to have a place to put a filter full of fuel. Ive never tested glow plugs, I jumped straight into replacing mine, but I'm sure somebody on here knows exactly what the resistance should be if you wanna get technical. Welcome to the diesel brotherhood!
Easiest way to do Glow plugs is to take a test light, remove the wire going to the Glow plugs as you do each one, connect the clamp to a positive battery terminal, and touch the probe to the top of the Glow plug. If it lights you have a good glow plug.
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
For air leaks, check the smaller hose off the top of the fuel filter and follow it down onto the engine injectors. That first hose segment is a common air inlet point, as is the return hose on the front of the Injection Pump. The problem occurs when the truck is shut down and a vacuum exists as the fuel wants to return to the tank but can only do so if air leaks in. If it leaks, the next time you go to start, the fuel filter header and IP is full of air that has to be displaced making for a hard start. A $30 kit will replace all the return line hoses and injector caps and o-rings.
Aubrey-Chinook, WA
87 F-350 XLT Lariat standard cab 2wd DRW, 6.9L and C6 w/cooler, 4.10 LS. Hypermax Turbo with 3-1/2 exhaust, US Gear OD, Powershot 2000 LPG. Cupholders and accumulated rust.
We had a very hard starting problem on our 7.3 IDI.. At first it was after sitting overnight. We could not get it started with
our killing the battery. We chased and repaired all of the vacum leaks we could find. Then if it sat for a week or more same no staring problem. I gave up chasing vacum leaks, instead we put on an additional pass through electric fuel pump, installed on motor side of the fuel tank switch. Problem solved.
The new electric pump is on a toggle switch. If the Motorhome has sat for more than a couple of days we run the pump for about fifteen seconds. No more hard staring problems.
Good luck.
Tars
1989 7.3 IDI Ford 27' Telstar motor home.
1987 460 ford in a 36' Grand Villa pusher
We have a 1987 Foretravel Grand Villa 460 Ford pusher, 92k miles want to convert to Navistar or power stroke. Also have a 1988, 89 title, 27' Telstar w/7.3 na International Navastar. 139k miles. The Diesel gets 7-11 mpg avg 10. The 460 gets 6-10 with a very strong tail wind on the flat. Avg 6-7 mpg.
How long does the glow plug light stay on when you first try to start? If it's for a few seconds only you need to test and if necessary replace the glow plugs with ZD-9's.
If your return line caps and O rings are good and not leaking, the fuel won't leak down to your tank. Before you go replace the fuel pump with an electric one, you need to replace the O rings and caps. That's the first order of business with the symptoms you have.
Ford recommends a 65,000 mile change interval for the fuel filter and they usually can go a lot further before needing to be changed.
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger, 52,000 Miles
'90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak, Retired 11/8/2011 with blown trans.
replaced the fuel filter, injector caps, o-rings and hoses. It still had a hard time starting this morning, but it was the coldest morning of the season (32 deg F). To really see if I've made a difference, I'll wait until a milder temp. morning and see if it starts any different. If I still have the same problem, what would be my next step? Injectors? The glow light stays on for about 4 to 5 seconds on a cold start. Is this long enough?
Your glow plugs may still not be working right. Double check all your grounds. Some times when you replace the cap and have the lines off they will still leak some air. I've had the same problem and just let it go a couple of days and it sealed it self. I guess it depends on if you feel lucky or not. You also can take a clear line and replace the return line from the pump to the last cap in line and see how many air bubbles you are getting when you start it. If it starts and isn't running rough from air in the line it has to be your glow plugs aren't heating long enough. Also make sure you have good batteries so it is spinning over fast enough.
1988 F250 7.3 diesel 4x4 auto C6 now ZF5
1990 F250 7.3 diesel 4x4 auto E4OD. now ZF5
1992 F250 7.3 diesel 4x4 ZF5
