Old 07-06-2005, 05:48 PM   #1 (permalink)
Hard Starting
Hi I'm newly registered on this site but have been using for the last few months or so while I've been working on this project. My question is
Truck just recently returned from it's date with the body man. Finalized all the fit and finish of the door hardware and interior. Truck probably hasn't been started for a month. She will start but it takes about 45 seconds to hit. I am baffled because the fuel system is new and so is the whole glow plug system. I guess I'll see if anyone here has any ideas
Ben
1991 F-250 4x4 7.3L ZF5spd Luk clutch and flywheel. Rebuilt Powertrain..drive axles..Engine Electical and glow plugs...New IP..injectors and fuel system...Complete Body off Frame Restoration. New Sheetmetal Cab/Bed/Clip...The only thing that is used to me is the dash and inteior door panels!!!!
BenTaylor is offline
Old 07-06-2005, 05:54 PM   #2 (permalink)
Re: Hard Starting
Can you hear the glow plugs cycleing? Did you change the glow plug controller when you changed the glowplugs?
"Daisy Diesel"1989 F-350 IDI 7.3 4 door dually Banks turbo Hays clutch Flatbed 2wd 4.10s zf-5
"Meat Wagon" 1989 E-350 IDI 7.3 Ambulance E40d 4.10s
nboehm is offline
Old 07-06-2005, 05:57 PM   #3 (permalink)
Re: Hard Starting
Everything is new down to the engine wiring harness. That is why I'm baffled [img]/ubbthreads/images/graemlins/frown.gif[/img]
On the cycling note you can hear it click on and then it doesn't cycle like it did the day I picked the POS from the bone yard!
Ben
Old 07-06-2005, 06:00 PM   #4 (permalink)
Re: Hard Starting
Check the fuel lines. The body shop may have knocked one of them loose and the fuel lines are getting air in them.
1989 Ford F250XLT Lariat extended cab 4x4 w/ N/A 7.3L, C6, 120k miles, & FlexSteel seats. Stock right now, but have a used non-wastegated Banks Turbo sitting in the garage (trying to find the time to collect the parts and install it) [img]/ubbthreads/images/graemlins/cool.gif[/img].
03/06 - Auto-RX done. Filter looked normal.
04/06 - Installed 100gal in bed tank for WVO.
11/06 - New rotors & pads
biosdude is offline
Old 07-06-2005, 06:03 PM   #5 (permalink)
Re: Hard Starting
Just got out from under it that was my first quess since everyone on here always talks about retun lines being the second thing to look at. All the SS lines look good and so do their connections and all the return lines look good.
Thanks again and thanks for your speedy responce
Ben
I think it's time for a 12 pack LOL
Old 07-06-2005, 06:04 PM   #6 (permalink)
Re: Hard Starting
might be a stupid suggestion but are the batteries new? could have lost some charge
i think a load test is in order
1989 F-250: supercab, long bed, 4x4, 5 speed,3.55's up front and rear, turned up pump,Pyro ofcourse!, custom stack, homemade lpg fumigation, more too come...At CSU, the black beauty is for sale...
nickbf2504x4 is offline
Old 07-06-2005, 06:06 PM   #7 (permalink)
Re: Hard Starting
New Autozone Duralast Gold bought them last night when I was pulling my hair out over this.
Ben
Old 07-06-2005, 06:09 PM   #8 (permalink)
Re: Hard Starting
Once it's warm, does it start easier? How long do you have to wait before it gets hard to start?
biosdude is offline
Old 07-06-2005, 06:12 PM   #9 (permalink)
Re: Hard Starting
How fast is it cranking? Maybe your starters going south. My old 6.9 would take along time to start just because it dident spin fast enough. I would also trying running a jumper on the glowplug controller just to make sure. hold the jumper there for about 5 seconds or so. Trial and error. How does the truck run right when it starts up?
nboehm is offline
Old 07-06-2005, 06:12 PM   #10 (permalink)
Re: Hard Starting
Takes about 45 seconds once she hits and warms up she runs fine and starts fine it's just the inital start and it's 90 today prolly 85 or so in the shop! The starter spins over not as fast as I think it should but again it's a newly rebuilt motor with 6 miles on the OD. The starter is New also.
Ben
Old 07-06-2005, 06:20 PM   #11 (permalink)
Re: Hard Starting
Gonna pull the glow plug controller. The guy at napa says he may be able to test it. So I guess we'll see. He'll prolly want me to pay him another 160 bucks for a new one LOL
On another note should I look into putting an Elec pump on this truck vs. the manual one. Would that make a real difference. My cousin who works for IH said that he didn't recommend it do to it could cause some sort of failure in the IP that he has seen over and over again, so I left it alone. Is he crazy or am I just grabbing at straws here.
Ben
Old 07-06-2005, 06:39 PM   #12 (permalink)
Re: Hard Starting
Theres ALOT of people who have done it, but I havent. My manual pump has lasted me 130,000 miles with no problem, so I figured it was doing its job right. Look up on how to test the pump here. Your supposed to get about 1/4 of a quart for about 10 secs I THINK. Just look it up, you'll see.
nboehm is offline
Old 07-06-2005, 07:01 PM   #13 (permalink)
Re: Hard Starting
The controller he says tests fine. What next other than finding a deep ditch to slide this thing into.
Old 07-06-2005, 07:52 PM   #14 (permalink)
Re: Hard Starting
I would bet on a bad GP controller. I had a good mech. at IH say that testing it on a bench was not reliable. You are not getting the after cycle. Check the GP's a few may be bad. Also I like the idea of jumping the relay on the GP controller and see if that fixes it.
Also you could place a piece of clear tubing in the return line from the filter to look for air.
Fuel, heat, air, and speed of spin. It should start...
Do not get frustrated, I will seem easy soon.
I also vote for adding the electric Fuel pump. Helps a lot with air issues. Make sure you get a good one if you do decide to do it. There is a fuel bypass so I can not dream of what kind of issues this would cause in a injection pump?? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1990 F-350 Dually 4X4 CC Rebuilt Turbo and NEW 7.3L DAS engine, rebuilt rear diff, Reman E4OD Stage 1 injectors Stage 1 pump Baumann recal kit and TDC for E4OD dead trans again...
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
DSBlack is offline
Old 07-06-2005, 11:59 PM   #15 (permalink)
Re: Hard Starting
Ben,
It could be air in your return lines. Have a buddy crank it while you depress the shraeder valve on the fuel filter header. Hold it until the air stops and fuel flows, then it should fire up. Check for wetness around the injectors. They may be wet, they may not be wet. Just because they are dry doesn't mean air isn't leaking in. It can leak air in without leaking fuel out. You can replace the fuel line from the fuel filter header to the number one injector with a piece of clear tubing. 12" long should do it. Get the truck running, then shut it off. Come back a few hours later and check for air in the clear hose. It will probably be filled with air. If so, I'd replace the return lines, caps and o-rings. Good luck, Tim
'94 F250, 4X4, 7.3, E40D, 4.10, 126K
tim94f250 is offline
Locate Ford Dealerships to find a new Ford for sale, Ford Mustang and other car models such as the
