search the archives for user and type in what you can think of
why do you ask?
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
I went to webshots, and he put a powerstroke intercooler on a banks turbo...just wanted to see what he used for the intake hat (the little piece that connects the discharge tube to the intake manifold)
89 F350 SRW Reg Cab 4X4, 3.55:1, ZF-5 w/ LUK single mass, added Banks sidewinder 12-06. So far so good. 17 mpg using B50 bio blend.
id use a plumbing fixture if it was me they make rubber hoses rated up to 15 psi plenty for a rad system withat overflow at 7 psi
just get 3 in to 3.5 in or waht ever you need its usualy like .25 to .5 thick
idk what he used though
