Re: Has anyone tried: Radius Arm Bushing Tensioner?
It doesn't go between the washer and nut, it goes BEHIND the washer and nut. Basically, they are selling you a pair of painted washers.
From appearances, it is just a washer with a hole the same size as the bushings, to compress them tighter.
The factory washer bottoms out against a step on the radius arm, this washer has a larger hole to go over the step.
Better to install a pair of urethane bushings that won't deteriorate like the rubber ones and be done with it.
*ASE Master Certified, Medium & Heavy Trucks*
