head gasket thickness
Just wondering if anyone knows if the felpro headgaskets have a thicker crush height than the factory ones. My problem is I have a 94 idi turbo and when the head gaskets blew the fire rings dug grooves into the block,the machine shop is supposed to be decking it today or tommorow but he thinks it will need about .004 to 010 in machined off,I am concerned about high compression,valve clearance and fuel timing from the reduced combustion and prechamber volume,I could machine the top of the pistons off and have them reanodized but that leaves me with a weaker piston and still a smaller prechamber,I plan on putting the aurora 2000 turbo on it with an intercooler and i expect 18 pounds of boost so I want all the strength I can get out of the piston. if anyone has any suggestions or specs of crush height on the factory headgaskets please let me know. I am also putting in arp studs,there is not a specific 7.3 idi kit so I took measurments from the engine and they sent me some that will work-just wondering if anyone knows what I should torque them to-the factory bolts were 100 for non turbo and 110 for turbo.
