Re: Which head goes on which side?
The heads are interchangeable. If you want them back as they came off you may be able to tell which was where by looking at the bracket mounting holes. The ones that were to the front should be sort of clean or at least look like they had bolts in them.
'90 F-450 SD, 7.3L IDI DSL, ZF-5 spd manual, 2wd, 11" x 10 spline clutch, 2-wd, contractors 10' dump box, standard cab, bench seat, Dana 80 rear w/4.63:1 gears, 174" wheel base (need lotsa room to turn),weighs in at a little over 9000, no frills.
'96 F-250 PSD standard cab, 2wd, E4OD, 328K on the clock.
