When I moved the truck out of the shop this morning I could hear a weird noise it sounded like presure being relived from a air line .It only does it while running and is the loadest under the truck It is not constant or does it happen at the same time intervals.But I did find while I was looking around that I have bubbles coming from the headgasket mating surface no water just all oily most of that I think has come from the valve cover.
350 Long Rod
89 F350 4x4 CC ,97 5.9 Cummins, Fuel plate ground to a 100 profile,boost set to 30 lbs 5spd 31/2 exh no mufler. boost&pyro gauge.2500 lb frame mount overloads.power stroke intercooler,Valaire clutch.pulling 33ft 5th whl, 2000 Tahoe transporter.Hauling Banshees one with a long rod motor and my own porting,T-3s single carb the other stock port with pipes.
Compression escaping from the head gasket would cause me some concern was this engine ever rebuilt or had major head surgery..
I think a compression test is in order...
It is all stock never been apart and has 130k on it.I am sure that the turbo has not helped the last 50k have been 75% towing miles.I will be pulling the heads next week weekend depending on time .
350 Long Rod
Refer to the previous poster,
if Pete tells you to do a compression test. Do it.
Smart
Now what are you going to do?
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
Since we have not been told the exact area of the bubbling/leak that info could provide us some insight as to whats going on where.
If the leak is at the back cylinder areas then I would assume the CDR may have allowed excess oil to enter the intake and migrate to the #7 and #8 cylinders.....
I have emailed you some info that has been posted many times re the CDR.
It was in the area of the back two cly on the drivers side. the cdr has been moved to before the turbo so any oil gets evenly sent to all cly now.Ever sence I put the turbo on there has been more and more sepage of oil I think it is just time for gaskets.I did over heat it going over the grape vine in Calf a few years ago also.
350 Long Rod
Could be a combination of a high boost to many times and the overheat situation......rearing their ugly heads.
