Old 02-12-2008, 12:52 PM   #1 (permalink)
Headlight Modification
Can somebody direct me to the brighter lights headlight modifications that shows the relays and wire scematic for this. Thanks, I looked for it but can't find it.
icanfixall is offline
Old 02-12-2008, 03:40 PM   #2 (permalink)
My Photos: (27)
Shouldn't need a schematic, like most all typical relay used circuits, a relay is energized with lo current for it to carry the higher amps from and to the higher amp component---headlights or whatever.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 02-12-2008, 04:22 PM   #3 (permalink)
88beast's Avatar
i think its on my website in my sig if not i have it somewhere
cdncarguy has it and 91diesel (anthony) has it
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 02-12-2008, 04:42 PM   #4 (permalink)
91diesel's Avatar
Send a message via AIM to 91diesel Send a message via MSN to 91diesel
I do? :P unless I forgot about it and lost it, I don't have it.
It IS fairly straight forward, though, if you know some electronics. Just get two relays, and some wire from radio-shack or wherever. Basically you put bigger cables in for more amperage and put the relays in-line with the cable. Trace your wires for the on/off and dimmer switch. I think you would use one for high beam and one for low beam as well as one for on/off. Don't hold me to this. Mine were always bright enough for me so I didn't do it. Course the only time I ever thought about it was back when I knew zip about electronics...now I love them.
1997 F-350, XLT, dually, crew cab, 7.3 PSD, E4OD auto, B+W turnover goosneck hitch, ts 6 pos. chip,
http://community.webshots.com/user/91diesel
**91diesel AKA anthony2010**
http://www.youtube.com/watch?v=fe622W_yZcQ
16.66MPG
[IMG src=file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-9.jpg][/IMG]
91diesel is offline
Old 02-12-2008, 05:24 PM   #5 (permalink)
Mostly what I'm trying to do is drop the electrical load on the stock headlite switch. I'm always concerned when I'm towing I will overload the dash switch. Plus getting brighter lites is a big plus.
Old 02-12-2008, 07:54 PM   #6 (permalink)
88beast's Avatar
sorry anthony i thought u sent me one once when i was looking into how to do it
u must just have said how to do it then or somin
88beast is offline
Old 02-13-2008, 12:39 AM   #7 (permalink)
Bill1013's Avatar
You will need 2 relays and 2 circuit breakers. Some 14 ga. wire. Female Quik Connect crimp on 14 ga. connectors to slide over the male relay connections and circuit breakers. Butte connectors for splicing. Soldering the splice connections is better, then use shrink tubing over the splice .
Relays--- Ford FOAB14B192-AA or AZone MR15 has attach bracket MR12 None or any compatable. Ford does not have an attach bracket. Junk yards should have plenty of these.
Circuit Breakers 1- LO Beam 15 amp 1 - Hi beam 15 amp RV stores have these or automotive stores.
On the relays #30 Com. B+ #87A NC #87 NO #85 coil B+ #86 B- These numbers are marked on the relay connection side.
On the headlights determine which wire goes to the LO beam and which wire goes to the HI beam , tag them as such.
Cut the wire going to the LO beam, leave some length to splice onto it , from the wire end going into the headlight splice on 2 wires one wire long enough to goto the other head light Lo beam, the other wire to #87 on the relay. The wire end left you cut to the Lo beam, splice a wire on and connect to #85 on the relay. On #86 relay terminal connect a wire to Neg. or frame. Now run a wire with the 15 amp circuit breaker in line from the battery to #30 on the relay. Test for working.
Now do the same for the Hi Beams. Use the 15 amp breaker in this battery line.
2nd Edit This is for the 9004 series bulbs. LO 55 watts Hi 65 watts. Don't know what amperage the 9007 series pulls.
DON'T USE FUSES -- IF THEY BLOW -- YOU HAVE NO HEADLIGHTS. The original circuit breaker is plugged into the fuse panel, leave it there. Your lights will go off and on if there is a problem useing circuit breakers.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo Radio SD & Tape 126,700 03/08 Strictly stock. Build date 03/99
Rebuilding engine. 92 F350 7.3 IDI CC LB 2WD Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
Reman IP - New Delphi Injectors -New Beru GP's 07/07 New radiator & hoses New WP
Dual Exhaust 3"X18" resonators frnt. of rear wheels
Soup bowl gone, 4" intake W/AZ filter
Cobra CB W/Weather Interrupt - Dual Trucker Antenna's
Blk. Grill W/Brush Guards - Fog lights - Rally driving Lights. GN 20K & Reese 16K 5er hitch
http://community.webshots.com/user/oldbull8?
Formally OLDBULL
Toys: 1984 Coachmen Leprechaun F350 Chassis 460CID 92K miles.
30 ft. Jayco Jay Designer 5th wheel.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One flash and it's gone.
Bill1013 is offline
Old 02-13-2008, 07:44 AM   #8 (permalink)
My Photos: (27)
[quote][The original circuit breaker is plugged into the fuse panel, leave it there. /QUOTE]
No, they've always been built into the headlight switch.
LMJD is offline
Old 02-13-2008, 12:49 PM   #9 (permalink)
Bill1013's Avatar
Stand corrected, thanks LMJD. Didn't actually check my 90 F350, my schematics show the circuit breaker in the headlight sw. up to the 88s then 89 up were changed. Oh well no harm done .
Bill1013 is offline
Old 02-13-2008, 09:51 PM   #10 (permalink)
Bill1013's Avatar
From that statement, could I take it you are more concerned about the trailer marker lite load ? If you are, you can use a relay at the rear if you have a B+ line going back to a 7-way trl. hook up. On a 7-way the GREEN wire powers the marker - tail and license lites on the trailer.
Remove the GREEN from the 7-way and use that wire to energize the relay #85 term. run a WHITE (B-) wire backout from the 7-way to #86 term. A Black (B+) out to #30 and a GREEN wire from #87 to where you removed the GREEN wire. Numbers indicate relay terminals . Above is true if the 7-way is hooked up to standard color code. If your trailer is an RV your prolly powering 16-18 bulbs , about 6-8 amps.
Bill aka Oldbull
Formally OLDBULL
Bill1013 is offline
Old 02-14-2008, 12:46 AM   #11 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Headlight mod.........
Whiter Whites, Brighter Brights .: Articles
Proud Canadian BOOB man too!!
cdnsarguy is offline
