Headlights keep flashing on and off? - Diesel Forum - TheDieselStop.com
Old 10-19-2009, 07:28 AM   #1 (permalink)
Just my headlights will flash on and off then i have to turn them off for a min and turn them back on and its fine for a few minutes sometimes longer then others. Does anyone know what is causeing this or had this happen to them? And it is just the headlights flashing the tail lights and parking lights are fine.
Thank you
1994 F-350 7.3 turbo diesel Vin K 4x4 Reg cab long bed 5-Speed 4 inch lift and 35's
94forddiesel is offline
Old 10-19-2009, 01:58 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (109)
I think there is a relay that does that when there is a problem....... How many lights do you have hooked up to high beams......
OK checking my schematic for 94 the headlights lights are on the PCM power relay. It powers the multi function switch and the main light switch. Check your light switch and connector for shorting out and burned.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 10-19-2009, 07:04 PM   #3 (permalink)
trampsdieseltruck's Avatar
My Photos: (33)
check the wires going to the headlight switch.i had the same problem,turned out that one of the wires at the harness at the headlight switch had come loose
1992 f250 7.3 nonturbo,4x4 360,000km,auto tranny
trampsdieseltruck is offline
Old 10-20-2009, 08:30 AM   #4 (permalink)
Thank you i will go try those things now and see what i come up with.
-Shawn
Old 11-18-2009, 09:04 AM   #5 (permalink)
Same problem here on my 90 f350 =( gets worse when i pull my trailer. I have read about wiring a relay but can not find out how to do that. Can someone please shed a lil light lol
1990 F-350 4 door Dully "love it"
sevennightclub is offline
Old 11-18-2009, 10:25 AM   #6 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Too many lights or a bad switch or connector........
Old 11-18-2009, 06:06 PM   #7 (permalink)
Check the electrical connector on the headlight switch. Mine was burnt, I ended up replacing both the connector and the headlight switch-both available thru Standard.
Common problem from what I have found.
1993 F-250 XLT 4X4 7.3 nat asp. Banks turbo installed 02/13/05, straight piped, 5 speed, 4.10 gears 235/85R16 stock wheels
1990 F-150 4X4 302 5 speed
1976 CJ7 4X4 258 3 speed
1995 Grand Cherokee 4x4 4.0 litre
1990 K-2500 GMC 4X4 350 Auto
1979 F-150 4x2 300/6 4speed 4bbl dual headers/exhaust
1986 Vacationeer 23' Fifth Wheel
2005 Gooseneck(brand) 4 horse gooseneck stock trailer
1941 Allis Chalmers C Ser# C541
1948 Allis Chalmers C wide front
ARIZHNT is offline
Old 11-18-2009, 09:17 PM   #8 (permalink)
RWF350's Avatar
[Same problem here on my 90 f350 =( gets worse when i pull my trailer. I have read about wiring a relay but can not find out how to do that. Can someone please shed a lil light lol[/quote] Look at LMC, they have a plug and play harness for going to the relays. I think it's about $30. By the time you buy wire, relays, connectors etc, it's not that much more than building a harness.
2007 Chevy 2500HD 4WD Ext Cab (late model) 6.0L (gas) 6speed auto
Deceased--1990 F350 2wd DRW Super Cab E4OD 7.3l IDI
Gooseneck hitch, Flowmaster (single inlet/dual out), 60 gal tank/toolbox/bedrails/headache rack (custom built, welded together as 1 unit), 3 gauge pillar pod w/glowshift gauges, oil, water temp, trans temp
Never ask "What else can go wrong?" cause something will.
RWF350 is offline
