Check Ebay. They come along all the time. Be careful about buying rebuilt heads. They can't be milled much at all and must be a certain thickness from the valve cover gasket rail to the bottom of the head. Someone will chime in with this demension shortly. I have it but its in the desk mess somewhere.... [img]/ubbthreads/images/graemlins/wink.gif[/img]
Per AERA specs:
Stem to guide clearance (intake & exhaust): .0013" - .0055"
Valve height (measured from top of valve to "deck" height)
Intake: .042" - .054" Exhaust: .051" - .063"
Minimum head thickness (from "deck" to valve cover surface): 4.7950"
If you need more let me know.
