Re: Heater Core.....
Easy as pie. The hardest part is cleaning the junk out of your glove box.
Clean out the glove box, remove the glove box by popping out the little plastic string on the left, and there's a latch on the right side, then tilt it down and out. behind that is the heater core. remove about 6 or 8 bolts w/ a 1/4 drive socket and a 6" extension,Remove the cover,
Clamp off the two hoses, and remove them, (Under the hood,)
Pull it out. Installation is the reverse of removal. Took me about 20 minutes, taking my time and goofing off.
Brake Fluid and Clorox makes lots of smoke!!
Note to self:
Do Not eat pink insulation.
It's NOT Cotton Candy!!
1988 F-250 4x2 5-speed 7.3 IDI
Building a www.Tremormuv.com Check it out!!!
