Old 10-24-2005, 12:19 PM   #1 (permalink)
Heim Joint Clutch Mod.
Just picked up all the parts for Ron's heim joint clutch pedal mod. I will be starting the project soon. Just checking to see if there is anything I should know before I start. Thanks
Jimmy C.
89 F350 7.3 IDI Diesel, 110,000 miles, Black and silver, single cab long. 4x4 XLT Lariat. 5 Speed Manual, very clean truck. Banks sidewinder kit, 4" dual stainless magnaflow exhaust, 4" skyjacker suspension kit with rear add leafs. Chrome Pro Comp wheels, 35" Pro Comp Mud Terrains.
JCDiesel89 is offline
Old 10-24-2005, 07:06 PM   #2 (permalink)
Re: Heim Joint Clutch Mod.
you should know that we need pictures. I need to do this as well.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
Old 10-25-2005, 08:41 AM   #3 (permalink)
My Photos: (23)
pictures along with the article are on oil burners dot net
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 10-25-2005, 04:27 PM   #4 (permalink)
[img]/ubbthreads/images/graemlins/biggrin.gif[/img].....Nice
A positive attitude. Have 2 trucks with the mod and love it.
Ron
My Photo Gallery
Goldie 1990 F-350 Custom 4x4 C/C DRW conversion. 7.3L Banks non-waste gated turbo, ZF-5 with 4" custom Exhaust complimenting a RDT venturi system, Autometer Pyro and boost 2 gauge pillarpod and your standard compliment of mechanical gauges. Clutch pedal Heim joint mod.
The Beef 1989 F-350 Lariat C/C DRW 7.3L N/A, ZF-5. Clutch pedal heim joint mod. Original price $500.00.
Currently slated for an extreme makeover ground up restoration.
Mater 2007 F-250 Lariat 4x4 6.9L IDI, T-19 trans pushing a 7'6" Western plow. Completely assembled from the tires up!
I got your "Jeep Thing" now it burns when I pee.
Dsl_Dog_Catcher is offline
Old 10-26-2005, 12:17 AM   #5 (permalink)
rawpower's Avatar
how big of a difference is noticeable and how is it noticeable?
1993 Ford F350 7.3L Turbo Diesel ZF S5-42, Divorced TS NP205, OEM locker/welded 2.5 ton Rockwells, 46" Michelin XML's, and some stuff too.
http://www.supermotors.org/users/RAW_POWER
rawpower is offline
Old 10-27-2005, 10:57 PM   #6 (permalink)
[img]/ubbthreads/images/graemlins/confused.gif[/img]
As far as the modification goes?
Clutch pedal is now stout and constant from the top of the pedal to the bottom of travel. No more pushing for a starting out gear accompanied by the "mash the clutch pedal to the floorboard" syndrom.
As for how?
Now I can easily disengage the clutch pedal to start the truck(s) and shift thru the gears without "grinding a pound"
Cost effectiveness was also a great factor considering the cost of replacement parts from the dealership or aftermarket locations versus total parts cost of the entire mod(under $10.00) [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Ron
My Photo Gallery
Old 10-28-2005, 09:30 AM   #7 (permalink)
Hey Dog catcher, is this the heim joint I need?
http://cgi.ebay.com/Left-hand-3-8-x-...QQcmdZViewItem
Also, I'm a little big to be wallowing around under a dashboard, would it be worth removing the master cylinder and doing the grinding and stuff from a standing position?
Brake Fluid and Clorox makes lots of smoke!!
Note to self:
Do Not eat pink insulation.
It's NOT Cotton Candy!!
1988 F-250 4x2 5-speed 7.3 IDI
Building a www.Tremormuv.com Check it out!!!
Camarogenius is offline
Old 10-28-2005, 08:25 PM   #8 (permalink)
CG,
Yes that will do the trick. Right in the ball park for pricing too.
As far as pulling the master cylinder yes it would be easier, but keep in mind you'll have to bleed out the slave afterwards. You will still have to get under there to remove the tab on the clutch pedal assembly to grind the post off there. Tried leaving it on the second truck but gave in as the post was not only tack welded into place but pressed onto the tab as well. PITA. Much easier to remove the tab. 2 good smacks with a hammer and punch and all is good.
If'n you were a little closser or feel like a road trip, would be happy to give ya a hand. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Ron
My Photo Gallery
