Help identifying OP sender? - Diesel Forum - TheDieselStop.com
Old 05-26-2009, 04:30 PM   #1 (permalink)
age
Hi, I've looked in my service manual and done some reading here and looked at photos but for some reason still challenged in locating the OP Sender. From what I've read, it should be top of rear of motor. I've removed the air cleaner and have left the turbo in place. I've done senders on other cars, usually a little canister with one or two wires, but feeling kind of dumb - can someone please help me identify what the OP sender looks like (size, shape, wires) and location in relation to the turbo? Thanks!
age is offline
Old 05-26-2009, 08:24 PM   #2 (permalink)
What kind of vehicle are you reffering to?
Information is important
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
Old 05-26-2009, 08:31 PM   #3 (permalink)
chuckster57's Avatar
IF it is a factory IDI turbo'd engine then the Oil pressure sending unit is mounted to the fitting on the top of the turbo. In the picture below it is in the middle of the photo and has the one wire attached. Disregard the vacum line..It was for a boost gauge and I move it to a different spot.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline
Old 05-26-2009, 10:27 PM   #4 (permalink)
age
Cool, thanks Chuckster - I just eyeballed on my truck and will get to testing her asap. It looks like it would be a snap to plumb in a new sender here, either mechanical or electrical, to get a better gauge reading. I'll do some more reading on gauge upgrades.
Sorry Bob, thought I had done my sig. It's a 94 F350 dually with 7.3 TD. I'm good for now, still got lots to learn about working on my first diesel.
age is offline
Old 05-26-2009, 10:33 PM   #5 (permalink)
So what's wrong...gauge not working?
Old 05-26-2009, 10:33 PM   #6 (permalink)
Bill1013's Avatar
[quoteSorry Bob, thought I had done my sig. It's a 94 F350 dually with 7.3 TD. I'm good for now, still got lots to learn about working on my first diesel.[/quote]
Put that info in your signature and location in your profile. Then all your future post's will be easier to get an answer.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline
Old 05-28-2009, 11:10 PM   #7 (permalink)
age
Thanks guys, sig is now updated.
Yes, guage isn't working. It worked for a couple of weeks, now is dead. I wanted to test the voltage output from the sender first.
AJ Goldsmith
1994 F350 Dually
7.3 IDI Turbo Diesel
Pretty much stock
age is offline
Old 05-29-2009, 08:37 AM   #8 (permalink)
88beast's Avatar
well u should see chuksters ****pit hes got more gauges than tires on that thing lol
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 05-29-2009, 09:32 AM   #9 (permalink)
Smile Allmost!!!!
5 gauges and 6 tires...looking to even the score
Old 05-30-2009, 12:07 AM   #10 (permalink)
age
Gauge problem turned out to be loose connection at sender. I'm going to replace the push on with a terminal connector and nut to keep it tight for the time being. Time to start looking for a mechanical gauge. I think I'll relocate the aftermarket gauge pod from below the dash to the a pillar. It has trans temp, boost and voltage. OP will make a nice addition and it will be nice to have them lighted too. Thanks again all for your help!
AJ Goldsmith
1994 F350 Dually
Pretty much stock
age is offline
