Re: help my poor truck
I had this prob too...
Check your speedo wire. It runs from your trans tail housing (or transfer case) up through your cab, under your floor padding and up into your gauge cluster. Make sure it is plugged in tight on both sides. If its not it will cause it too get good readings, then bad readings, then no readings at all. And with bad or no readings, it will through off the computer for the transmission.
7.3 IDI F-350 4x4 1990
-Custom: '92 interior; Banks Y Pipe, Flowmaster muffler and Dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
-Soon to come-
Mid 80's front clip
Matching fender flares
Black paint job with chrome trim (fender flares, grill, bed runners, wheels, exhaust stacks, windshield trim, bumper)
2.5" leveling kit
4.6l Mustang GT 1997
-Custom side exhaust (no mufflers, Ford Racing Exhaust tips
-Aftermarket stereo (Alpine headunit; JL Component Speakers; JL 300x2 Amp; JL 10" W7 Sub; JL 500x1 Amp)
GOTTA LOVE FORD MUSCLE
