Old 04-29-2005, 03:53 PM   #1 (permalink)
HELP PLEASE - Won't start - just clicks on 90 7.3
Hello experts,
I've decided to sell my truck as it just doesn't get used like it should. I have a guy coming to see it in a couple of hours so I went to get some fuel and she just clicks. The batteries are charged so I need some advice to get her going please. I did wash her a couple of weeks ago and sprayed off the engine as well, however I had no starting issues until now. I've done this before with no negative results - I hope I didn't mess something up!
1990 F250 Supercab Lariat 4x4 E4OD 3.55's all Stock.
Jayman is offline
Old 04-29-2005, 04:19 PM   #2 (permalink)
Re: HELP PLEASE - Won't start - just clicks on 90 7.3
Just thought I'd mention that the glow plugs are cycling and after the light goes out when I crank it just clicks. Sounds like it may be coming from the solenoid area if that helps.
All input appreciated please - I'm in a bit of a panick.
Thanks again
Jayman is offline
Old 04-29-2005, 04:36 PM   #3 (permalink)
How many miles?
When was the last time the Lift Pump was replaced?
How about the fuel filter?
How full are the fuel tanks?
Any prior syptoms?
How long, (exactly) does the WTS light stay illuminated?
Why panick? Got a big date tonight?, Is it parked in a No Parking area?
Stick or auto?
Fill in the bottom of your post, this is required to join the "Club"!!
Giter done
BB
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
Old 04-29-2005, 04:46 PM   #4 (permalink)
on my 6.9 there was a wire from the starter to the relay on the fender. That wire broke on me, and had to be changed. It went to the sol. on top of the started. Also I would start by replacing the relay on the fender and check the battery connedtions. If she wont crank has to be starter or power related.
Turn on the lights and see what they do when trying to crank. If they go out or almost out then you have bad batteries or connections.
Let us know.
Sell her to a good home. Most of us around here treat these rigs like one of the family. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
1990 F-350 Dually 4X4 CC Rebuilt Turbo and NEW 7.3L DAS engine, rebuilt rear diff, Reman E4OD Stage 1 injectors Stage 1 pump Baumann recal kit and TDC for E4OD dead trans again...
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
DSBlack is offline
Old 04-29-2005, 04:50 PM   #5 (permalink)
The problem is it won't crank. 222000km on it and she has fuel with a recent filter etc. Changed return lines and injector seals etc and WTS light stays on about a minute or so. When I turn the key to start I get 1 click - that's it. It's an auto by the way and I have a guy coming over to see it in about an hour because it's for sale.
Jayman is offline
Old 04-29-2005, 04:59 PM   #6 (permalink)
Thanks for the tips - is there any way to check the solenoid and relay?
Jayman is offline
Old 04-29-2005, 05:21 PM   #7 (permalink)
The one on the fender wall is too cheap to check, just replace it $12US, NAPA,
yes, there is methods to check it, but it requires prior education and a meter.
Old 04-29-2005, 05:45 PM   #8 (permalink)
My Photos: (24)
from my own experience when it clicks but wont cranck it is the starter. it happened to me, i replaced the starter and problem solved.
my 2c, exekiel
- 12/92 f350 jasper 7.3L 17k Torito
- Home made exekiel propane system, sweet
- Home made ram-air system
- 4.10 open, DRW
- zf5 trans (dextron and militec); 12" luk solid fly wheel and clutch set.
- exekiel coolant filter system (Fleet-guard filter and dca)
- ip runing with stanadyne every tank and Mels timed.
- Agnem manual tranns starting system :-)
- Hypermax turbocharger system YES Finally. Turned up a la Travis.
crew cab/ wood interiors/ 800w cd player. Sweet ;-)
2 new diamond headlights
4 100w flash lights and 2 withe fog lights
more pics
BOOB Man
soon..
- paint job.
exekiel69 is offline
Old 04-29-2005, 06:23 PM   #9 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Jump the two large posts on the relay on the fender see if it starts the starter motor. The other thing could be the gear shift wiggle it the MLP may be just out of alignment, or put it in nuetral.
Last but not least try to roll the engine over in a clockwise rotation at the crankshaft/balancer 15/16 socket see if it is hydrolocked, since you stated WASHED engine.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 04-29-2005, 06:29 PM   #10 (permalink)
Give your starter a tap with a hammer (not too hard) then try it. If that doesn't work get someone to turn the key while you tap the starter. When my starter went I did that for a couple months until I fixed it. It was intermittent at first so I let it slide.
Steve
Eric -> '92, F250, 7.3l IDI, extracab, longbox, one ton spring in the rear,Borg Warner 1356 transfer case, 12500lb winch. 280k km. Since purchased in June 2003 repairs include: ball joints, tie rod ends, all u joints, water pump, radiator, brake calipers, brake pads & shoes, rear drums, front wheel bearings & seals, rear axel seals, replaced transfer case, rebuilt rear differential, replaced bent drive shaft, replaced drive shaft support bearing, K&N air filter, dual 2.5" exhaust.
Mango is offline
Old 04-29-2005, 06:36 PM   #11 (permalink)
Might also add to check and make sure the grounds on the bottom of the block,2 on front lower front edges, are making good contact.
Ron
Ron
My Photo Gallery
Goldie 1990 F-350 Custom 4x4 C/C DRW conversion. 7.3L Banks non-waste gated turbo, ZF-5 with 4" custom Exhaust complimenting a RDT venturi system, Autometer Pyro and boost 2 gauge pillarpod and your standard compliment of mechanical gauges. Clutch pedal Heim joint mod.
The Beef 1989 F-350 Lariat C/C DRW 7.3L N/A, ZF-5. Clutch pedal heim joint mod. Original price $500.00.
Currently slated for an extreme makeover ground up restoration.
Mater 2007 F-250 Lariat 4x4 6.9L IDI, T-19 trans pushing a 7'6" Western plow. Completely assembled from the tires up!
I got your "Jeep Thing" now it burns when I pee.
Dsl_Dog_Catcher is offline
Old 04-29-2005, 08:20 PM   #12 (permalink)
Get it running yet?
Do you get one click and if you try the key again, does it click again? and what do the lights do(this will give you a sign of the condition of the batteries)See if it will spin by hand, Still sounds like a power, starter, or hydro lock problem....
DSBlack is offline
Old 04-29-2005, 09:23 PM   #13 (permalink)
If he's driven it since the "wash job" (said it was a couple of weeks ago)it wouldn't be likely to be hydrolocked. Sounds to me like a bad solonoid. I'd try jumping the terminals as stated above before I tried anything else...
My pics...
Sorry to all the loyal 7.3 guys, but I traded my '91 7.3 in on a 2002 F250 Ex cab V10 4x4. SCT Xcalibrator2 with tunes by Powerplay Performance. 285/75/16 Toyo M/T's. Took a long time to get used to the ping-pop of a cooling catalytic converter...LOL.
'85 Bronco swapped up to a 302 4bbl from the 300 I6, NP435 4spd, NP208, 32x11.50x15 Radial RVT's, Soon to be 6.9 turbo powered.
86 F350 Cab&Chassis with a dump bed. 2wd 6.9 and 4 spd tranny. No mods to engine.
2000 Volvo 660 N14 Cummins, 500hp 1650 ft lbs, Autoshift tranny 10spd.
What part of "SHALL NOT INFRINGE" do you NOT understand?
aceohearts is offline
Old 04-29-2005, 10:39 PM   #14 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Several possibilities after a wash job:
Excess water sitting in the head (low spot for the GP)...water may have seeped through a loose GP into the cylinder....or
Water ingestion into the air cleaner/intake via the hold down bolt.....can cause hydrolock....
Old 04-30-2005, 02:23 AM   #15 (permalink)
Hello everyone and thank you all for the input. The guy never showed - figures. I did however get it going after charging the batteries. I guess when I blew off my alternator belt awhile ago it must have drained the batteries down more than I thought. All is well - so far!!!
Appreciate it
Jayman is offline
