Help. Is Starter Bad? No Start - Diesel Forum - TheDieselStop.com
Old 06-26-2009, 05:14 PM   #1 (permalink)
I have to start my truck with starter fluid every time I drive. After sinking several hundred dollars and multiple attampts at repairing the glow plug system I gave up.
So Ive noticed my starter has been slowing down over the past week or two each time I cranked the truck. I went to crank it to go do a job, it started turning over, then wound down like the batteries were dying. I put them on charger over night and went back this morning to try to crank her again.
Again turning over was slow then RPMs just died down. Turn over was not fast enough to fire the starting fluid.
I then took the batteries out and to an alt rebuild place. He tested the batteries and said they were good /excellent. Brought batteries back, put them in after cleaning all contacts with battery booster and a battery brush. Greased terminals with grease. secured all terminals. Went to crank it and it sounds as if the starter is running but not engaging.
the problems seem to be just getting worse
any help appreciated
1990 F-250 - 7.3L - 4X2 - w/super heavy welded bumpers, desert tan paint job and khaki wheels. Everything else is stock and as spartan as possible. no clock, no radio, no comforts, built for working.
Upstate South Carolina, "The foothills"
warhorse is offline
Old 06-26-2009, 06:36 PM   #2 (permalink)
asauer's Avatar
Send a message via MSN to asauer Send a message via Skype™ to asauer
Most likely a bad starter- but before/while you take it out, inspect your cables very thoroughly. You've already cleaned up where the batteries are, which is good, but also clean up the engine block grounds. Visually inspect the entire length of each cable to ensure there are no abrasions which have compromised the protective jacket- they will rot away if so. Also look at where the insulation stops on each end of the cables- if the wire is corroded back into the insulation, they are junk.
On the positive side, I almost guarantee your truck will start quicker, and without ether onces you get the proper cranking RPMs.
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
Member of Indiana Air National Guard 122FW MXS
asauer is offline
Old 06-26-2009, 06:58 PM   #3 (permalink)
Snotzalot's Avatar
Starters don't last for ever.
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger, 52,000 Miles
'90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak, Retired 11/8/2011 with blown trans.
7.3L Alternator Belt Idler Photos
Snotzalot is offline
