I Want to build a High performance IDI. Need Injector pump help, turbo etc. First of All is it possible, second who else has one. shop info, web sites, anything would help.
99 Extended cab short box
Blackwidow transmission
DP Tuning
FASS 150/180 pump
DI Peformance stud's
Swamp's Gen 3 oil
Spearco 6.0 CAC
AFE Stage 2 With Progard 7
Coming soon...
Bigger TN charger, Injectors, Built motor
Custom pulling hitch, ladder bars, bump stops, weight rack
Goldie 1990 F-350 Custom 4x4 C/C DRW conversion. 7.3L Banks non-waste gated turbo, ZF-5 with 4" custom Exhaust complimenting a RDT venturi system, Autometer Pyro and boost 2 gauge pillarpod and your standard compliment of mechanical gauges. Clutch pedal Heim joint mod.
The Beef 1989 F-350 Lariat C/C DRW 7.3L N/A, ZF-5. Clutch pedal heim joint mod. Original price $500.00.
Currently slated for an extreme makeover ground up restoration.
Mater 2007 F-250 Lariat 4x4 6.9L IDI, T-19 trans pushing a 7'6" Western plow. Completely assembled from the tires up!
Yup, Ken at DPS is the man for IP,Injectors or anything HO for the IDI. He will be able to set you on the blessed course, he could probably even hook you up with a twinds set up!! Anyhow, good luck and tell us what you are doing, you have peaked our interest. Scotty
Don't think I've ever used IDI and high performance in the same sentence until now. [img]/ubbthreads/images/graemlins/smirk.gif[/img]
95" Extd Cab F250HD 4x4 DRW, /86"6.9 T19 GV o/d 3.73 axles, Hypermax Pulse turbo, intercooled / Modified Hypermax ram air induction, PowerShot 2000 LPG system "first design". Ride rites @ all 4 corners, Dana 50 mono Beam up front, Ford 10.5" in rear with 4 wheel disk brakes. Other Truck, 1983 IHC "S" with 14ton NoMar wrecker body, 30,000 GVW, 229"wb with a 6.9L IDI, Clark 5sp, 5.57 rinp&pinion, turbo charged and intercooled (with LPG soon).
Im just tired of the cummins boys having all the fun with the mechanical injection. I want something that will put out some power. Has anyone had an IDI that will put 400-500 horsepower
DP Tuning
FASS 150/180 pump
Swamp's Gen 3 oil
Spearco 6.0 CAC
Coming soon...
Ken at DPS can help. The IDI isn't a very powerful engine... can be made to produce power, but the Cummins will make as much or more power and will last longer doing it.
I've talked to Ken about building me a twin-turbo IDI... good for a 13 second quarter mile and for hauling a 10,000 pound horse trailer as well or better than the new trucks.
Can be done... but longevity is questionable as are the ability to keep EGTs down and engine temperatures down.
- SOLD: 1991 F-350 XLT crewcab, dually. BTS E4OD. My favorite truck.
- NEW DAILY DRIVER: 2006 Ram 3500 SLT quad cab. 5.9L Cummins, 6-speed manual transmission, nav system, Jake brake. No mods, now or ever. 100% satisfied.
Twin turbos, Head Studs, Lower compression, better Rods, High output injector pump, Propane injection, Water/Meth injection, better head gaskets. If I had some spare money, that's what I would put into one of these old girls [img]/ubbthreads/images/graemlins/grin.gif[/img].
Better yet, I'd like to build a souped up Non-turboed IDI. Same stuff just substitute the twins with lots of Nitrous Oxide [img]/ubbthreads/images/graemlins/biggrin.gif[/img]. I can see it now...I drive up to BD power dyno days and run with the high RWHP boys. To see the looks on their face when I tell them that is a 1989 Naturally Aspirated Diesel. Man, would that be fun or what!!!
With twin turbos, and an intercooler, I bet you would have to really be honking on the go pedal in order to make EGT's unreasonable. Twins would be moving ALOT of air, and if you had a solid top end you should STILL have a long and healthy life, if you are not beating the SNOT out of the truck EVERYDAY. I am sure the engines are plenty strong enough, just takes some tweaks to keep everything in place. If I didn't have my truck down for HG's I would run one of Kens twin turboed IDI's in one half a heartbeat. Scotty
actually,Factory Turbo IDI rods are stronger than Pre PM powerstroke rods.In the same area a PSD rod breaks the Turbo rods have a larger cross section.
Here is what you will need for mega power
Lower compression pistons(Cut down Mahls are Ok since they are Forged)
Polish,Pined,Cryoed turbo rods
Studs
Fire ring the block/head
stronger valve springs
Reground cam(optional)
port polish heads,intake manifold and exhaust(headers?!?!)
Higher boost turbo to feed the low compression pistons
Big ol honkin exhaust system
Intercooler
water/meth injection
Propane
Nitros(only with fire rings and studs!)
Very hungry IP with matched set of injectors
Guages out the wahzoo
Bored and sleeved block
and finally,a strong tranny.A stock E4OD or ZF will end up a paperweight in a hurry with the kinda power the above will make set up right.
IDI Till I Die!!!
NCC-1701UAV U.S.S. Enterprise -1991 F350 CC dually.Lighted heated west coast mirrors,Nathan Airchime K3HA air horns,attitude from hell itself!
1994 F350 Crew Cab Dually,7.3 IDI turbo-Currently in the Roundhouse awaiting 10 year overhaul. White Lightning
1971 M35A2 deuce and a half.6wheel drive,Power Nothing!125 Horses in a 13,000lb truck.Real get up and go power! Martyr Machine
Man, I really wished I would have talked to Ken sooner. His twin turboed 300HP IDI is about 2x as much as me doing the HG's. Kinda stinks, I would have foregone getting a Jeep trailer and just had him build my engine. That would have been great, but his phone call to me was a few days too late, but with the set up I have, I really don't have too much trouble getting my junk pulled around. Scotty
Speaking of which! About 2X the head gasket cost is how much? How much is he asking to do a 300 RWHP IDI?
P.S. (Freight_train) That's a good list! How much money do you think the hardware for that would cost (less the propane, Nitrous, and Tranny). Also, I don't have turbo rods in my 1989 N/A, and I was talking about using billet rods.
A fire ring is traditionally cut into the head with tooling that turns a perfect circle, and once the SS wire is inserted into the carefully prepared grove, it will clamp tight against the fire ring that is built about the head gasket cylinder opening (I've done a number of the 12 valve Cummins heads when I worked @ BD power) If you look at an IDI head gasket, the circle is not perfect, in fact it takes quite a jog where closest to the nearest cylinder. I'm not sure what kind of tooling you'd use to machine that sort of "indented" circle, but if it were possible I imagine it would be prohibitively expensive.
As another cautionary note, what sort of increased thermal stress do you think the pre-cups are going to take before they start following glow plug tips out through the tail pipe?
Not saying the power can't be achieved, but the notion that it will do that and last for ever has got to be debated. Playing the devils advocate here, on the other hand, what the heck its only money!
1990 F250 with 325oookm - ATS (non wasteGated kit ) on since 0km's / ZF / Single Cab Conversion to 6 seater keeps the family involved / Getting on, but running strong
A CNC set up on any good mill would be programable to cut any type of groove in the block easily. The hope of 400 to 500 hp at the rears wheels on the street isn't going to happen. Maybe 300 but anything more is like top fuel and being streetable..... [img]/ubbthreads/images/graemlins/eek.gif[/img]
The fire rings we use on diesels are not like the "fire rings" or wire used on blown gas engines, or the fire rings that BD uses. The fire ring used is a .110" thick perfectly concentric ring, basically a jumbo-sized o-ring. A groove is machined into the block just outside of the cylinder wall for the ring to sit in, and ultimately crush into. The stock head gasket is then water-jet cut to sit around the new ring. The purpose of the head gaskets then becomes nothing more than to seal the water and oil passages. The new ring is sealing 100% of the compression.
On an idi it is difficult to get fire rings to seal properly, mainly because of the pre-combustion chamber. The ring will sit directly under the chamber, and if you don't have a good chamber to head seal or the chamber is not exactly flush with the head when torqued down the ring will not seal against the head.
The fire rings used are currently holding in 115+psig of boost on a 7.3L powerstroke. The other trick to get fire rings to seal is you need to keep the heads down, but that's no longer an issue.
In a daily driver, the pre combustion chambers can be left alone. In a high performance application we port them. I have had no issues with melting, breaking, or otherwise destroying the pre combustion chambers, both high performance and daily driver.
Build the engine properly, don't take shortcuts (I know, most of the time that's not cheap), tune the engine properly, and it will last.
