I have a technician that works for me that has hockey pucks for cab mount bushings. He swears it rides fine. I can't tell, 79 Bronco on 6" suspension lift w/38"? tires. I know it does free it up to use regular bolts, nuts, washer, etc. I've got to replace mine because of broken hardware. Some bolts are snapped of IN the t-nuts. Just wondering if anybody else has experience with using hockey pucks.
Deceased--1990 F350 2wd DRW Super Cab E4OD 7.3l IDI
Gooseneck hitch, Flowmaster (single inlet/dual out), 60 gal tank/toolbox/bedrails/headache rack (custom built, welded together as 1 unit), 3 gauge pillar pod w/glowshift gauges, oil, water temp, trans temp
Never ask "What else can go wrong?" cause something will.
Ah the poor mans lift. I've seen it on lifted trucks as well, but have heard that its not a very good idea. From what I understand is that the pucks can crack in half and completely fall out. The stock isolator bushings are a much better and safer way to go.
My 2 cents.
1971 F250 Camper Special 390, c6 auto, 4x2, 63k original miles, rebuilt engine. It's had a hard life.
1984 F250 6.9 IDI, 4-speed manual, 4x4. Rolled so now its a project.
1985 F250 351W, C6 auto, 4x4. Dads truck.
1988 F250 7.3 IDI, C6 auto, 4x4. Bought it with new heads and rebuilt injection pump. Since then new parts include ball joints, brakes and brake components at all wheels including parking brake cables, fuel sending unit, injector return kit, belts, starter, batteries, and alternator. Sno-way 9'1'' v blade. Ready to make some money!
That's my thoughts as well. I wish Moog or somebody similar would make an OE bushing set. So far all I have found is LMC ($120 just for bushings & hardware under radiator support)or Ford (which is double LMC's price).
Its a polyurethane set so you are in luck there. I will replace mine with these after this winter.
Napa sold me a set of poly-urethane cab mounts for my '80. Can't remember the name though (I do know it wasn't an "Energy" product). They were a nice addition to my body lift, as they took away a lot of the body sway.
05 F-350 Crewcab 4x4, 6.0, Auto, Dually, My new Tow Rig
95 F-350 Crewcab 4x4, 7.3, Auto, Awesome Tow Rig...Sold on May 17/09 (went to a good home)
80 F-250 4X4, 429, 4 Speed, Lifted, Solid Axles, Boggers, 450,000km and going strong...Gonna Go
90 Bronco, Work in Progress
Yep used a stack of three back in the late '80s for body lift. Sold the truck years later and none were cracked or broken. The ones I used were hard rubber IIRC. That was on a Nissan 4x4, never tried it on a Ford.
1986 F350 Crew Cab 2wd SRW. 1991 7.3 IDI, T-19 4spd Sterling 10.25 3.55, 12" HD clutch. A Banks waste gated turbo. 5" cut down Peterbilt stack. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W85 high performance zero-gel diesel! D60 front conversion, 4wd conversion, dually conversion, and steel flatbed conversion now underway. Man those frame rivets are a pain!
1966 Porsche 911. 1983 911 SC engine with modified Zenith carbs, headers, 911S brakes, custom fuel rails, MSD 6al box with timing computer, 1974 IROC body kit. 1850lbs, 200rwhp, total blast to drive.
Now I remember the name...it was "Prothane" bushings.
