i am getting horrible mileage i have a 7.3l idi turbo and i am getting on average 6mpg i have 38.5 in tires what kind of gears would be good idk what is in it but floored on the highway i mak out about 75-80 top speed any suggestions on what i could do to get better fuel economy if it is even the gearing? anything other than gears that anyone can think of?
2003 F350 Lariat, 4x4, CC, SRW, Dark Green Fx4 SOLD
1995 C3500 6.5l work trk, 2x4, CC, DRW, white DECEASED PREMATURALLY
2003 JEEP WRANGLER, ooooops, not anymore!
1986 26' Seaway Northstar w/ 454 Mercruiser
2008 Montana Mountaineer 332PHT
1991 GMC Topkick, CAT, 4' vert. gang boxes, 12' dump. if only all were as reliable!
tall tires give you higher gearing ,thats why to keep the same power and gear ratio its necessary to change the gear set. taller tires to lower gears you can also jack up your truck -draw a line on the bottom of the tire to the floor - and mark the driveshaft against the diff . then rotate the tire one complete turn while counting how many times the drive shaft rotates , for example 3 3/4 would be 3.73 gears i have 33 's on my truck and ihave to add 8-9 miles per hundred on the trip od for the correct millage [ checked against two diff gps 's ]
To the original poster - yes, if you have 3.55s with that large tires you do need to regear. Our engines make most torque in the 1600-1800 rpm band, while being most efficient about 200-300 rpm lower than that, so if you're in the 1300-1400 rpm range when you actually demand high torque output you'll be loading the engine a bit too much and you'll be burning fuel like no tomorrow.
__________________ The more I drink, the more I drink, the more I drink...
'90 F350 XLT Lariat, reg cab, dually, 4.10s, factory tow package, Chevy hydroboost conversion, P3 brake controller - the Hay Express
