horse power - Diesel Forum - TheDieselStop.com
Old 06-01-2008, 05:29 AM   #1 (permalink)
horse power
I have a 92 7.3 with 250k miles I do alot of towing pulling 15k lbs recently going up large inclines I'll get some black smoke not alot but whenI get over the hill or mountain I'll get gray smoke when on the flat accelerating it does go away after a short while
all tempatures are well within normal ranges fresh fluid changes oil trans and rear end
and another question what is the hp of a 7.3 stock and can i increase it with something simple or do I have to much wear and tear on my poor truck.
thanks
fcra is offline
Old 06-01-2008, 08:45 AM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Turbo would be the best power increase...........
6.9 - Max H.P. 175 Torque 318 ft. lb.
7.3 - Max H.P. 185 Torque 338 ft. lb.
6.9 max torque at 1800 RPM
7.3 max torque at 1600 RPM
Both max HP at 3300 RPM.
Any wet spots on the fuel lines, fuel filter header etc.....
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 06-01-2008, 11:28 AM   #3 (permalink)
would turbo put to much strain on the lower end with the amount of miles I have?
and no fuel leaks that I can see
fcra is offline
Old 06-01-2008, 01:13 PM   #4 (permalink)
skunk's Avatar
i dont think so. if you dont go with a turbo turn up your IP and go with a better flowing air intake and exaust set up. there are turbo IPs and Injestors also.
Northern Woodland & Tree Care work trucks:
old smokey
- 86 Ford F250 6.9 IH navistar non-turbo idi diesel 4x4 dana 60 rear w/ limited slip, dana 44 front wishbone style, w/ 3.55 gears, C-6 w/ oil coolers, manual walbro frb-13 fuel pump, manual wellman glow plugs, K&N air filter no soup bowl and a homemade cold air intake, 3 inch pipe, class 31 heavy duty tractor truck batterys, lots of real gauges.
big drippy - 86 Ford F350 4 door crew cab, long box, 7.3 Navistar IDI non-turbo diesel, 2wd Dana 70 dually rear with 4.88, c-6 w/coolers.
The Swan - 87 chipmore wood chipper chuck and duck old school style. vm motori sun 4505 3.9 air cooled non-turbo DI 4 cyl diesel, rockford pto.
skunk is offline
Old 06-02-2008, 10:19 AM   #5 (permalink)
hesutton's Avatar
My Photos: (30)
The lower end of the motor is not an issue. Never heard (not to say it can't happen) of an IDI with bottom end failure with a turbo. Now headgasket are another story..........More so with the 6.9 than the 7.3. I'd say turbo and enjoy.
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
7.3 Project Pictures
Webshots Project 7.3 Gallery
hesutton is offline
Old 06-02-2008, 02:16 PM   #6 (permalink)
xtremefreerider's Avatar
Bottom End
The bottom end is pretty strong. The headgaskets are the weak point. I ran over 200k on my first motor (turboed at 75k and ran 12psi) till it lost a head gasket, it then hydrolocked and I lost the bottom end. I would do a turbo, intake and exhaust. If you don't want to spend the money, start with intake and exhaust with an IP adjustment. REMEMBER if you adjust your IP/Install a turbo you MUST install a pyrometer. These motors get real hot real fast after you tweak them.
-Brian
1990 F-350 REG CAB LONG BED, 7.3 IDI, '95 ZF-5, LUK CLUTCH W/ SINGLE MASS FLYWHEEL, 87 BW 1356 T-case, FOUR GAUGE PILLAR MOUNT W/ AUTOMETER BOOST, PYRO, OIL PRESSURE AND WATER TEMP, BANKS SIDEWINDER WASTEGATED TURBO, EAGLE 16.5" WHEELS, 4 INCH SUPERLIFT, 35/12.5/16.5 BFG Muds, Eaton Rear End (7/05), Blown Motor (9/05), New motor, trans and t-case (9/06), Custom 5" straight pipe (8/07) - Pics coming soon....odometer rolled for the second time...although I don't have the correct spedo gear and the spedo/odo didn't work for 15-20k miles
MY PHOTOS
The Goat - 2008 Dodge 2500 CC LB 4x4, 6.7L Cummins w/ 6sp manual. So far bone stock except a leveling kit
xtremefreerider is offline
Old 06-02-2008, 03:07 PM   #7 (permalink)
I installed mine (turbo) at 246,000 miles after swapping the heads for reman. and repaired all engine oil leaks. I resealed the fuel return and replaced the glow plugs also. Repair/replace anything that is suspect before/during the turbo install. It made all the difference for towing.
1993 F-250 XLT 4X4 7.3 nat asp. Banks turbo installed 02/13/05, straight piped, 5 speed, 4.10 gears 235/85R16 stock wheels
1990 F-150 4X4 302 5 speed
1976 CJ7 4X4 258 3 speed
1995 Grand Cherokee 4x4 4.0 litre
1990 K-2500 GMC 4X4 350 Auto
1979 F-150 4x2 300/6 4speed 4bbl dual headers/exhaust
1986 Vacationeer 23' Fifth Wheel
2005 Gooseneck(brand) 4 horse gooseneck stock trailer
1941 Allis Chalmers C Ser# C541
1948 Allis Chalmers C wide front
ARIZHNT is offline
Old 06-02-2008, 06:13 PM   #8 (permalink)
7.3L F-250's Avatar
My Photos: (16)
Send a message via AIM to 7.3L F-250
dad had about 270k on his 90' 7.3 when he put the turbo on it and no problems other then the headgastkets going and the engines still running strong
and one thing about these engines is they make peak hp at 3300 RPM and there governed at 3350 or 3450 i cant remember the exact number
company trucks
2002 ford F-350 powerstroke cc sb zf-6
1987 ford F-350 6.9L idi flat bed
1989 ford F-350 7.3L idi pick up
CURRENT PROJECTS
1978 ford F-350 custom
7.3L F-250 is offline
