Old 04-10-2005, 11:10 PM   #1 (permalink)
How do I remove the power steering pump pulley?
I have a 93 that needs a new power steering pump. I have removed the entire bracket that the pump is mounted in, how do I remove the pulley so I can change the pump?
Thanks.
93idi is offline
Old 04-10-2005, 11:14 PM   #2 (permalink)
Posts: n/a
Post deleted by JLester
Old 04-10-2005, 11:32 PM   #3 (permalink)
Re: How do I remove the power steering pump pulley?
Thats a tuff one to pull off without the special puller. Most auto parts stores will rent you one as stated above. I went and bought mine for about $60.00. Works great too....
icanfixall is offline
Old 04-12-2005, 08:41 AM   #4 (permalink)
A hydraulic press would probably do it also.
Perry
1992 F350 Crew Cab, 7.3l IDI, LWB, 4x4, E40D trans, 170,000 miles so far.
http://www.pbase.com/drz400/truck
perryg114 is offline
Old 04-12-2005, 09:15 AM   #5 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Normally if you use the proper tool you are not require to remove the accessory bracket. A hydraulc press used during removal would be cumbersome and may cause damage, it would also not be of any use when reinstalling as the pulley has to be pulled on to the shaft. There are several inexpensive Ford etc power steering and alternator pulley removers out there.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 04-12-2005, 09:58 AM   #6 (permalink)
Location: Black Diamond, Washington The evergreen State
I called around and ended up taking mine to the local cheveron where they have mechanic on duty. $15.00 bucks and It was swapped out. So you might call around and see what you can find.
1986 ford F250 xlt lariat 4X4 supercab 6.9l idi 162835 miles. With soup bowl mod. Purchased used in 1992. Stock except the custom body work on rear fender well, done by a 80 foot tree. You should of seen the tree it got the worst of it. Slight dent in front bumber from VW that slid in front of me. Missing the label on front hub courtousy of a cougars head hitting it a 50 mph. Cougar lost that one also.
93 ranger 4 banger and 5 speed stock
66 mustang convertible pony interior 289 2v 4 sp
57 thunderbird 3 speed auto 312 thunder special with 2 4v carbs and continental kit
56 ford f100 wrap around window project vehicle
1999 gmc suburban I new I shouldnt bought a chevy
duanero1 is offline
