Re: How far do most turn up the pump?and does the timming need to move also?
I turn it all the way up, then back it off a 1/16th or so, then drive by the pyro. Not going to hurt it driving with all the way truned up, just don't let it get above 1250 pre turbo, and you should have no problems. Scotty
Oh, no need to move the timing if it is timed to specs, which is 8.5BTDC, at that timing with the turbo and fuel maxed out, you should come clsoe to 13-15psi of boost and alot of great power. Scotty
Semper Fi
Scott Beretz
2006 Dodge Megacab 4x4, Cummins, 6 Speed, Airbags, Quadzilla Commander, XZillaraider 2, 285/75R17 Toyo OC AT's
Pulls a: 3814SS Keystone Raptor Toyhauler w/Quads
