how many volts out of gp relay - Diesel Forum - TheDieselStop.com
Old 05-26-2009, 04:49 PM   #1 (permalink)
trugertha's Avatar
i was wondering what kind of voltage i should get coming out of the gp relay?
1991 ext'd long box
7.3 idi E4OD ttb
264,000kms
had 162,000kms when i bought it 3 years ago
trugertha is offline
Old 05-26-2009, 06:58 PM   #2 (permalink)
trampsdieseltruck's Avatar
My Photos: (33)
i get 9.6 volts when the "wait to start light" comes on
1992 f250 7.3 nonturbo,4x4 360,000km,auto tranny
trampsdieseltruck is offline
Old 05-26-2009, 07:09 PM   #3 (permalink)
trugertha's Avatar
i get 11.5.. do you think i should replace the controller?
1991 ext'd long box
7.3 idi E4OD ttb
264,000kms
Old 05-26-2009, 09:37 PM   #4 (permalink)
My Photos: (33)
does the truck start ok.did you test the volts at the controller relay or at one of the wires going to the glow plugs.take one wire off of one of the glow plugs and hook up the (+) end of the volt meter and ground the (-) end.turn the key on and check the volts
Old 05-27-2009, 12:56 AM   #5 (permalink)
trugertha's Avatar
yes i did test at relay, ill test at wire in the morning..hopefully the new gp's fixed my problem and she'll go first thing, without plugging it in haha
1991 ext'd long box
7.3 idi E4OD ttb
264,000kms
Old 05-27-2009, 06:43 AM   #6 (permalink)
My Photos: (33)
when you installed the new glow plugs did you use anti-sieze in the threads
Old 05-27-2009, 09:01 AM   #7 (permalink)
Snotzalot's Avatar
Beru states antisieze isn't required.
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger, 52,000 Miles
'90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak, Retired 11/8/2011 with blown trans.
7.3L Alternator Belt Idler Photos
Snotzalot is offline
Old 05-27-2009, 12:17 PM   #8 (permalink)
trugertha's Avatar
not required but never hurts haha
1991 ext'd long box
7.3 idi E4OD ttb
264,000kms
Old 05-28-2009, 12:39 AM   #9 (permalink)
trugertha's Avatar
hmmm i had it working this morning 9v at gp connector then this after noon nohting no volts at the other side of the relay...but 12 on the hot side...i can hear it click when i push the button for my manual plugs, but no drop in voltage on my stock meter and no volts show up on my voltmeter either.. i assume relay ???
1991 ext'd long box
7.3 idi E4OD ttb
264,000kms
Old 05-28-2009, 04:33 PM   #10 (permalink)
trugertha's Avatar
fixed!!! thanx everyone
1991 ext'd long box
7.3 idi E4OD ttb
264,000kms
Old 05-29-2009, 02:45 PM   #11 (permalink)
What was the fix?
bonezie121 is offline
Old 05-29-2009, 04:03 PM   #12 (permalink)
trugertha's Avatar
it was the relay, the controller is shot 2 but i just hooked up a manual switch, until i can afford a new controller, then ill set up a manual and the stock system
1991 ext'd long box
7.3 idi E4OD ttb
264,000kms
