Re: How much HP can one of these motors be pushed to.
Safely [img]/ubbthreads/images/graemlins/smokin.gif[/img] these motors can push 325 hp at the flywheel. Now if you use studs in the heads, propane, water-methonel injection and nitrous you will have about 450 or maybe a little more at the rear wheels but... Its not a grocery getter any more. Add an intercooler and boost it up to about 19 lbs and you get more but again its not something to just tool around town in. If you raise the boost you need to drop the compression ratio down from 21 1/2 to 1 to about 18 to 1. Otherwise the heads probably will lift. Copper head gaskets and o-ringed heads and block are a good idea but the heat cycles will cause them to leak over time.
