How much for new fuel tank sending units? - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 32 (permalink) Old 12-31-2011, 06:28 AM
drinkypoo's Avatar
My Photos: (25)
You don't even have to cut it at a 45, make it five inches long and clamp it on and you can make it bend 90 degrees at the bottom of the tank, in that little well. Since the stock fuel pickup has a bypass on it that opens when the filter screen clogs, you're not really losing any protection either way.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #17 of 32 (permalink) Old 01-01-2012, 12:24 AM
Lightbulb
I had a sender that didn't work ( 2 tanks).... I ran the tank dry, put a piece of carpet under it and undid the straps,lowered it down,, hit the ring and popped the sender/fuel pickup out .... in my case the float split and filled up and sank....... but I went to picanpul and dropped some tanks from ford pickups ( no vans)_ ... they use that sender unit, a printed circuit board with a wiper on the board...... I think they are common to lots of fords of that era...... not hard to fix at all..... I got spares while I was at the yard, not a hot-moving item.. I tried to get a sender from ford .... no dice part NA anywhere... fixed it myself, so can you
'91 E350 7.3 , facet Duralift fuel pump , snglmass flywhl, ZF 5spd trans, 2 piece drive shaft, 3.55 d60 lsd moosiahmobile project.... '81 volksdiesel Frankenbunny ,more Audi than Golf OR Rabbit!
moosiah is offline
post #18 of 32 (permalink) Old 01-01-2012, 11:42 AM
drinkypoo's Avatar
My Photos: (25)
My brass float was full of diesel too. I emptied it out, cleaned it with alcohol, and patched it with a little dab of RTV. While I was in there I took a file to the end of the wire that wraps around the float and beveled it off so it wouldn't hole the float again. So far, so good.
post #19 of 32 (permalink) Old 01-05-2012, 05:36 PM Thread Starter
nbkr341's Avatar
Lots of good info in here guys thank you. I will get Dad and his gearhead buddies to take a look at it. Would it be easier to drop the tanks or lift the bed?
93 Ford F250 7.3 IDI
2wd
E4OD Auto
31" bfg all terrains
Just rolled 100k original miles
nbkr341 is offline
post #20 of 32 (permalink) Old 01-05-2012, 09:42 PM
drinkypoo's Avatar
My Photos: (25)
for doing both tanks definitely easier to lift the bed. you take some hose clamps off the filler, and the screws out, and they let go. this assumes you can get your bed bolts free. I drilled some out, ground some off, and managed to loosen some.
post #21 of 32 (permalink) Old 02-03-2012, 02:46 PM Thread Starter
nbkr341's Avatar
What all do you have to do before lifting the bed? I assume disconnecting brake lights and such.
2wd
E4OD Auto
nbkr341 is offline
post #22 of 32 (permalink) Old 04-30-2012, 02:30 PM
Fuel Tank Sending Unit.. 1989 F250 7.3L
I would like to put new Fuel Tank Sending Units into the dual tanks of my 89 f250 7.3L. Two dealers said not availabe any more. Napa, Autozone, and Oriellys said not availabe.
Does any body know where I can buy new ones or rebuilt ones? Is there a different year or model that would work? Any other ideas.
The Fuel Tank Sending Unit for my truck consists of a variable resister, controlled by the action of an attached float in fuel tank. Resistence should be 160 ohms (full tank) and 15 ohms (empty tank).
Any help would be appreciated.
Redrobert
redrobert is offline
post #23 of 32 (permalink) Old 04-30-2012, 05:35 PM
drinkypoo's Avatar
My Photos: (25)
you could try hacking 10-180 ohm Float Arm Fuel Level Sender - R89890 | ISSPROGAUGES
more seriously, you should read '83 - '86 CFI/EFI Fuel Sender Repair
it says The '83-'86 CFI/EFI sender is very different from the sender for the carbureted cars. It's actually a lot like the sender for the
'87-'93 cars, but the resistance range is 80 Ohms empty and 10 Ohms full, while the '87-'93 sender is 10 Ohms empty and
165 Ohms hen the tank is full. Since I wasn't having any luck finding the E3ZZ sender, I started looking around for other Ford
senders that could be used as organ donors, to repair my existing sender.
[...] the 1984-1987 Tempo/Topaz, 2.3 Liter,
without fuel injection. [...] This sender is Dorman part number 692-120, or Ford part number E63Z-9275-A.
So if you get in there and find a ceramic element you can almost certainly get a new one from the above.
One site says you can clean your ceramic element with MEK, which you can generally get at a hardware store near you (even in California! edit - but since you live in TX you can get damn near anything)
The Nissan EXA / NX Club - since 1997 - How to Clean Fuel Level Sending Unit !!
post #24 of 32 (permalink) Old 04-30-2012, 10:43 PM Thread Starter
nbkr341's Avatar
Redrobert
Check out Rockauto.com that's where I got mine. Replaced both with no problem.
2wd
E4OD Auto
nbkr341 is offline
post #25 of 32 (permalink) Old 04-30-2013, 01:47 PM
Sending units
Old thread, but same problem!
Just checked Rockauto.com and they no longer list them. Instead, I found a specialty shop in up-state NY that rebuilds your sending units.
Guy's name is Dan and he owns tristarrradiator.com which rebuilds sending units and that is all he does! Used to do radiators, but gave that up to concentrate on sending units only.
Should be pretty reasonable to get the old originals rebuilt. Between $60-$100 he said.
1992 2WD F-250 SuperCab 7.3L 5-spd 4.10 rear. Changed to 5w-40 Rotella Synthetic oil in the crankcase & Deep Purple Synthetic ATF in the Trans. 38K on new Jasper longblock, Bought truck from local University (MSU - 09/20/06). Replaced O-rings on return line caps with Viton. Now on to tackling Biodiesel!!
kleenax is offline
post #26 of 32 (permalink) Old 04-30-2013, 11:13 PM
Have you tried LMC Truck? They had them last I looked but may be only for the 90+ model years.
Cheers!
'91 F250 4x4 7.3 IDI
XLT Lariat - Super Cab - Long Box
Z5 Five Speed
UNDER CONSTRUCTION
DanielH is offline
post #27 of 32 (permalink) Old 05-01-2013, 08:53 PM
mf7lakes's Avatar
Try these guys.
website: www.tristarrradiator.com
1993 (new in 10/'92) F350 crew cab XL, 7.3L IDI, 4X4, 5sp manual,C5 axle 4.10, 78,000 mi.
'96 F150 XLT Super Cab LWB 5.0L 4X4 Auto-trans
mf7lakes is offline
post #28 of 32 (permalink) Old 07-27-2013, 08:58 AM
Blue Ridge's Avatar
Send a message via MSN to Blue Ridge
Cheers!
I know this is kinda an old thread, but I'm having gauge issues, so I've been searching.
It looks like LMC does handle the parts you mentioned. I've bought lots of stuff from them in the past. Most of their stuff is cheapo-Chinese stuff but it's reasonable. Their customer service is terrible, don't expect to talk to anyone who knows anything about auto parts.
Bill
89 F-350 crew-cab rollback 7.3
Blue Ridge is offline
post #29 of 32 (permalink) Old 07-27-2013, 09:40 AM
In an earlier thread on "fuel lines" I mentioned that my fuel Gage stopped working. I used to judge my fuel consumption by the miles driven on the odometer but it became a real nuisance. So, last week, I dropped the tank from underneath after buying a mechanics creeper from Harbor Freight and started the process. I'm 76 years old so don't let the task deter you from doing it yourself. Just takes some time.
After getting the tank out from under the truck, I didn't visibly see any problem with the sending unit after going through all that work. However, as I mentioned before, the float felt heavier than necessary and after placing it in a pan of water, it sank. The float seems to be made out of a very thin piece of brass tubing with caps on each end and mine had several hairline cracks on the sides. Seems kinda of strange to have stress marks on something that just floats in diesel fuel but that was the case. So, I drilled out the end to express any fuel and treated it with JB Weld to seal the cracks. Than just to make sure, I took drinkpoo's advice and coated it again with RTV sealant.
Today, I filled it up with fresh fuel and so far ever thing is ok. I had some apprehension when switching to this tank thinking that I would have all kinds of air intrusion form the empty fuel lines but it didn't miss a beat.
A gentleman by the name of Bill on here said that Car Quest had floats available but I couldn't find them. Might be specific to locality.
Bottom line is don't shy away from the job if you have the time. You could do it in one day but I had the luxury of spreading out. Treat the tank straps with PB Blaster before you start.
1994 F250 HD, IDI Diesel, 3:55 gears, K&N filter, Hayden Tranny Cooler, Monroe HD SensaTrac shocks, dual pillar pod with temp & tranny guage, poly fuel tanks
caseyj is offline
post #30 of 32 (permalink) Old 07-27-2013, 09:48 AM
I would be soldering the brass personaly, use silver bearing solder, sand the float down so it was even and shiny, coat it in flux then heat it up so the solder melts the second it touched the float, put enough on to coat the entire thing! (This will not effect the weight by much at all!)
now it is protected and slealed. Personaly I do not trust any chemicle seleant to be in a fuel tank for any length of time!
New truck: 1988 F-350 1 ton dualy 2*4, 7.3L IDI Naturally Aspirated, Dual tanks with Camper package.
Mods: Enhanced gauge cluster; Transmission temp, rear diff temp, coolant system pressure, Vacuum pressure, Fuel pressure, Crappy tire Air horn Kit, Raycor pre filter/water sep. All LED Dash lighting, Parker LFS tranny filter, super duty tranny cooler, gerret turbo, waste gated (pending).
Xeonpony is offline
