How to prime??? - Diesel Forum - TheDieselStop.com
Old 11-09-2012, 08:56 AM   #1 (permalink)
How to prime???
I just put my 7.3 IDI into my new truck and I'd like to be able to prime the fuel lines without draining my batteries and having to keep charging them.
REDNECKIT is offline   Reply With Quote
Old 11-09-2012, 08:57 AM   #2 (permalink)
Also was wondering how to overrun my park/neutral safety switch (ZF5 tranny).
Old 11-09-2012, 09:26 AM   #3 (permalink)
chuckster57's Avatar
As long as the fuel delivery and return systems are intact, there is no reason to prime. My truck can sit for 2 weeks and still start within 2 seconds.
As for bypassing the clutch switch, you just have to jumper the wires, I don't have a clutch so I'm not sure which ones. LMJD know I think.
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now   Reply With Quote
Old 11-09-2012, 09:27 AM   #4 (permalink)
drinkypoo's Avatar
My Photos: (22)
You can swap to a racor filter head/bowl that has a primer pump
you can add a primer pump, e.g. from a diesel mercedes, you need the part the pump screws into, not just the pump part itself
You can remove your filter, and fill it with fresh fuel. Which is what we normally do.
Hmm, edit, I assumed you meant you installed a new engine
As chuck says, you shouldn't lose prime. There's lots of opportunities for leaks in the fuel system, though.
drinkypoo is offline   Reply With Quote
Old 11-09-2012, 09:35 AM   #5 (permalink)
Wrencher's Avatar
The switch on the clutch pedal. Just unplug and make a spaded jumper.
2002 F-350 CC Shortbed, 7.3 Powerstroke,150K, DIY BHAF, EBV brake mod, fuel shim. Built tranny w/ triple disk Torque convertor and shift Kit, 4" Lift, 35" BFG KM2, TS Performance 6 Position, Banks Big Head Wastegate, 4" Duals, Superlift Air Bags, B&W Hide a ball W/ 5th Wheel Companion, Marinco mod
LOCAL 3 OPERATORS UNION
Wrencher is offline   Reply With Quote
Old 11-09-2012, 10:04 AM   #6 (permalink)
NH2112's Avatar
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
The red w/blue stripe wires at the clutch pedal switch are the ones you need to jumper. The other 2 are for the cruise control if present.
Phil
1991 F350 Lariat XLT, 7.3l, 5-speed, crew cab, SRW, 3.55, 2WD. 115K original miles.
1990 Jeep Wrangler Sahara, 4.2l, 5-speed, Dana 30/35 w/3.07s (for now!), 33x10.5x15 BFG Mud-Terrain KM2s on 4" Rough Country springs. Engine being rebuilt after an awesome afternoon in the mud LOL
NH2112 is offline   Reply With Quote
Old 11-09-2012, 10:05 AM   #7 (permalink)
My Photos: (27)
There's more to it than that. Most have cruise control and there'll be two speed control cutout wires at the switch too. Can't recall the color codes but what's what can be determined with a test light.
Looks like Phil and I posted at the same time. Great minds think alike.
LMJD is offline   Reply With Quote
Old 11-09-2012, 10:08 AM   #8 (permalink)
Oh, perfect, thank you guys. Appreciate the help
Old 11-09-2012, 10:11 AM   #9 (permalink)
Wrencher's Avatar
So just butt connect them together. And its as simple as that.
Old 11-09-2012, 10:24 AM   #10 (permalink)
what is youre NEW truck?
jasonm11 is offline   Reply With Quote
Old 11-09-2012, 10:29 AM   #11 (permalink)
Perfect, just wanted to check before I started connecting wires
Old 11-09-2012, 10:30 AM   #12 (permalink)
Its a 1997 F350 that had a 460 with an auto tranny, so I took the 1992 7.3 IDI and ZF5 out of my wreaked truck and just in the process of buttoning everything up on it
Old 11-09-2012, 01:09 PM   #13 (permalink)
So are you only trying to prime for that initial start after installing the 7.3?
Or are you worried about losing prime routinely?
Interested to hear how your project works out.
Rob
94 Ford F350 7.3 idi Turbo
Long Box, Crew Cab, 4x4
"Texas Truck"
This is my sons truck!!
iowa-rob is offline   Reply With Quote
Old 11-09-2012, 01:28 PM   #14 (permalink)
My first thought would be to install the FF topped off with fuel, then crack the injector lines to bleed the air. Cracking the lines is what I did a couple times while getting the feel of where my tank pick-ups bottomed out.
'91 F350 usually-running project!
bdhutier is offline   Reply With Quote
Old 11-12-2012, 07:59 PM   #15 (permalink)
Yea just the initial prime. I was thinkin today cause I just put the fuel sending unit in the old gas tank and it doesnt look like it sits how the fuel tank does on the diesel so it might not have been picking up the little bit of fuel I had in there either.
