Old 08-30-2008, 11:50 PM   #1 (permalink)
My Photos: (14)
How rare is this? Thinkin bout adding one to the fleet
At the Case IH dealer where i work, setting in the back doing nothing is a 88-91(dont know what year) F-350 dually, Reg. cab, factory 4x4, 5 speed, XL with tilt & cruise but no A/C. Got about 240 on the clock, stacks and a Featherlite aluminum flatbed. Thats the good, the bad is the front end needs a total rebuild(it will drive but everything is shot), and the tranny bellhousing is cracked on the top(can anyone tell me what causes this and what the significance of it is, or what will happen if it's left that way?). So basically needs a front rebuild and a different tranny, the engine is good...runs like a champ(i got there about half hour early one mornin and checked it out while nobody else was around). Everybody else there thinks its a P.O.S., but i think its neat and i see potential in it....good project truck....maybe 92-97 front clip, dash, interior.....you know. The guy that owns it says hes gotta have $2500 for it, im thinkin about it pretty hard. What do ya'll think? But this actually is a pretty rare bird aint it?
2000 F-350 Super Cab,Long Box,4x4,7.3L PSD, Bully Dog Chip,6 sp. LEVER ACTION, Camper Pkg.,160k,Lariat,White on top,Gold on bottom,Gold interior. 285/75/16 BFG's
1993 F-250 Reg. Cab 4x4. XLT. 7.3L IDI, E4OD, 4.10 rear, Baldwin coolant filter. Born: 9/92, 160k, Lumbar bench with armrest. White on top, blue in middle, white on bottom. Clearence lights,DeeZee diamond plate running boards to back of cab. True dual exhausts with glasspacks and 4" stainless tips. Pretty well stock except for Pioneer CD player. ***OUT OF SERVICE***-Needs engine, tranny, and 4 tires, as of 12/1/06-shavings in oil.
rossman is offline
Old 08-31-2008, 01:23 AM   #2 (permalink)
Well, I'm not familiar w/ those options, but it sounds like a "normal" farm truck to me. Yes, most 1 tons end up being extended cabs usually. I've seen 1 ton reg. cab dualies. The bed is a not an issue...could remove the factory and put a flat bed (many here do it).
The tranny, is the bell housing a separate deal, or is it "part" of the transmission case- as in some automatics? Next question is, how is it cracked? Is it going from the block to the tranny and completely split or is it near a mounting bolt?
If the entire front axle is shot, a used axle might be cheaper then rebuilding it. Bushings and leaf springs could be bought online or pulled of a junker truck.
The price of $2500, I bet the owner is thinking that if he parter it out, he'd make that much. A running engine and aluminum bed would fetch a nice price. Then the rear axle and body parts (doors).
If you know what's wrong with it, look around. Try to price a bell housing (if it can be replaced) and a tranny (if not). Then price a used front axle and springs. If you can do the work yourself, might be worth it.
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is offline
Old 08-31-2008, 05:05 AM   #3 (permalink)
Kinda rare to find the duel rear wheels with 4WD
1993 Ford Bronco, 351W, Manual transmission swap (M5OD) THE TOY
1996 Ford F-150, 300 I6, Manual transmission,2WD 157,000 miles, going up for sale to get my diesel
I SPEED UP TO RUN OVER HYBRIDS
B-rad is offline
Old 08-31-2008, 09:34 PM   #4 (permalink)
I could enjoy watching it right where it is for a long time before I coughed up $1000, much less $2500 for a worn out work truck. I only buy things if the seller is motivated and obviously this guy doesn't care so no deal for me.
Think about what rare means. It means they weren't popular when new. Add up the costs of what it would take to get this truck to where you want it and see if you can find one already in that condition for the same price.
Things that crack the bell housing:
1) Shoving in reverse while having forward motion
2) Bell housing bolts loose.
3) Dowel pins missing. The pins take the torque of the motor, the bolts just hold the two together.
Now days, a cracked bell housing isn't trash. A welding shop can fix you right up.
A.K.A. Sign_man
1988 F-Superduty bucket truck, 7.3 IDI, LuK Clutch, 5 spd, 4.10 rear
http://photos.thedieselstop.com/show...=70062&thumb=1
Phillipmc1268 is offline
Old 08-31-2008, 10:47 PM   #5 (permalink)
I would say thats a bit pricey considering the work it needs. The bell housings are not replaceable. weird you mention a crack like that. the trans i bought my truck with had a crack that started at the top bolt and ran down through the starter housing.
Mine was fine for about a year that i had it but then all hell broke loose. The TC was banging around the flywheel was smacking into the bell housing. ugly situation. needed a new trans.
I do have an extra auto 4x4 trans for that style truck. Brand new never installed. Has all the updates. I bought it at $2K.
7.3 IDI F-350 4x4 1990
-Custom: '92 interior; Banks Y Pipe, Flowmaster muffler and Dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
-Soon to come-
Mid 80's front clip
Matching fender flares
Black paint job with chrome trim (fender flares, grill, bed runners, wheels, exhaust stacks, windshield trim, bumper)
2.5" leveling kit
4.6l Mustang GT 1997
-Custom side exhaust (no mufflers, Ford Racing Exhaust tips
-Aftermarket stereo (Alpine headunit; JL Component Speakers; JL 300x2 Amp; JL 10" W7 Sub; JL 500x1 Amp)
GOTTA LOVE FORD MUSCLE
Cjhstang is offline
