I finally tracked down the problem with my wipers. I have power to the motor for all 3 speed settings (low, high, intermittent) but no movement, so it looks like the motor is dead. Is this just a matter of removing the bolts holding the motor in place, or do I need to replace the cowl piece at the base of the windshield to do this. I'm hoping the motor is an easy swap because there are thunderstorms predicted for today! [img]/ubbthreads/images/graemlins/eek.gif[/img]
Any guidance would be greatly appreciated.
Jeff
Jeff
1992 7.3 non-turbo, F-350 2WD Crew Cab Dually E4OD 4.10 limited slip rear (Passed on to younger brother in 2006)
2004 Dodge 3500 Cummins 4WD Quad-Cab Dually Laramie
2003 Jayco Eagle 325 BHS
Not sure about your '92, but on my '91 it involved removing the wiper arms and cowl and then taking a few onces of skin off trying to squeeze my hands down in and around the motor to remove the nuts and washers. It's one of those "Not too difficult, but irritating as hell" jobs. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Sorry to all the loyal 7.3 guys, but I traded my '91 7.3 in on a 2002 F250 Ex cab V10 4x4. SCT Xcalibrator2 with tunes by Powerplay Performance. 285/75/16 Toyo M/T's. Took a long time to get used to the ping-pop of a cooling catalytic converter...LOL.
'85 Bronco swapped up to a 302 4bbl from the 300 I6, NP435 4spd, NP208, 32x11.50x15 Radial RVT's, Soon to be 6.9 turbo powered.
86 F350 Cab&Chassis with a dump bed. 2wd 6.9 and 4 spd tranny. No mods to engine.
I went to turn on my wipers today and nothing happened.So,I get home,open the hood,turn the key on ,and turn the wipers on. They dont work but i do hear a faint noise from the motor.I assume this means the switch is good but the motor is shot.Is this correct? How much is a new motor?
218,000 miles 1989 F-350 7.3 Litre New IP AT 190,000 Original injectors
Double check all connections, especially for a good ground........
cdnsarguy-
Thanks. I didn't check the ground connections, just used a test light to check for power. I'll hook to power and check the ground now.
If it's not a wiring problem, is the motor difficult to remove? I see 3 bolts that hold it in place, but how difficult is it to undo the linkage? Is it only screws that hold the vented area at the base of the windshield in place? Does that even have to be removed? I swear, between power windows and wipers... [img]/ubbthreads/images/graemlins/shrug.gif[/img] I guess if you hang onto a vehicle for 13+ years it will start to show its age!!
Thanks-
Jeff
Jeff
Hey, I did my motor a few months back and it was not to bad a job. I did have to take off the entire piece just aft of the hood as well as a few other pieces. It probally took me a couple of hours to finish everything. Man what a difference being able to see makes!!
1992 ford-250 4x4 supercab diesel straigh drive almost everything is original. 265,000 miles, just got this truck. I don't think the previous owner fixed a thing. Items replaced/repair so far: wiper motor, automatic locking hubs(they were lock all the time and installed WARN manual hubs, repaired door hinges, all tie-rod ends, drivers side window motor, new parking brake cable, 8 new glow plugs, LUK solid flywheel, all new u-joints, new fuel pump and the list of needed repair is endless...
