How to replace lift pump - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 10-16-2008, 11:37 AM Thread Starter
Steve250's Avatar
Hey guys, I am going to replace the fuel lift pump on my truck within the next few weeks. I am wondering first of all where the lift pump is on the engine. Secondly I am wondering what tools I will need to do the fix. Thirdly I need to know where I can get a good fuel pump. I assume I will need a bosch?
And last but not least I need to find out how to actually do the fix.
Thanks in advance,
Steve
'92 F-250 7.3 IDI Diesel 4:10 (99k) 4x4 ext cab (Prodigy brake controller
'98 Ranger 4x4 ext cab - wheelin' in the mud
John Deere 510D Backhoe - it's not a ford, but it's nice
Steve250 is offline
post #2 of 16 (permalink) Old 10-16-2008, 12:52 PM
The lift pump is on the front passenger-side lower corner of the block, same place where Chevy engines have them. You can get a pump from a parts store, or order on online, either way it should be about $35. Tools you will need - 3/8"-drive ratchet, some extensions, and 1/2" or 9/16" sockets, also for the fuel lines you'll need some open-end wrenches (I'd think 9/16" or 5/8") for the steel line and also a screwdriver for the shot hose between the frame and the pump.
M.L.S.C. is offline
post #3 of 16 (permalink) Old 10-16-2008, 02:07 PM Thread Starter
Steve250's Avatar
is there any kind of specific pump that is good or not?
Steve250 is offline
post #4 of 16 (permalink) Old 10-16-2008, 03:06 PM
Snotzalot's Avatar
My Photos: (5)
Napa, Carquest. This type of fuel pump is hard to make a bad one.
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger Cream Puff, 92,000 Miles, 5.4L Gasser
'90 E350 7.3L Ex-Ambulance High Top 420K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak. 10 wonderful cool years using Freeze12 without any AC system modifications. Retired with blown trans.
Snotzalot is offline
post #5 of 16 (permalink) Old 10-16-2008, 03:15 PM Thread Starter
Steve250's Avatar
What's the difference among these three?
NAPAONLINEŽ)
NAPAONLINEŽ)
NAPAONLINEŽ)
Steve250 is offline
post #6 of 16 (permalink) Old 04-30-2009, 05:19 PM Thread Starter
Steve250's Avatar
My dad just bought the pump for $150, I thought that was a little high. The guy said thatr it was new... and that the $40 ones were rebuilt. Is it high?
Steve250 is offline
post #7 of 16 (permalink) Old 04-30-2009, 05:31 PM
trampsdieseltruck's Avatar
My Photos: (33)
$150 for a fuel lift pump??????????????
1992 f250 7.3 nonturbo,4x4 360,000km,auto tranny
trampsdieseltruck is offline
post #8 of 16 (permalink) Old 04-30-2009, 06:04 PM
I got mine for around $40. I would take the $150 one back. Mine came with a 1 year warranty, but I expect it will last a lot longer than that. Make sure you get the arm on the right side of the camshaft, you can bump the starter to find the sweet spot. I never did find the so called sweet spot, it takes a fair amount of patience. I recommend you remove the alternator to give yourself an easier shot at it from above.
1994 F-350 CC LB SRW 4x4 5 spd. manual. Homebuilt vegetable oil fuel system coming soon installed. 253k, 1k on vegoil.
Dads truck - 1997 F-350 CC LB SRW 4x4 5 spd. manual. Stock except for the vegistroke fuel system, over 90k on WVO. 230k on the truck.
TWeatherford is offline
post #9 of 16 (permalink) Old 04-30-2009, 06:20 PM
cdnsarguy's Avatar
My Photos: (109)
This is the pump required........or a crossover brand..... visit my photo link for pics of old and new..
This info pertains to Carter #M60278 pump or new long arm style.
WARNING
This fuel pump must be installed only at the low position of actuator cam.
If the pump is installed at any other position than low cam, the pump will be ruined, the engine will stall and damage may result.
Incorrect installation will loosen the pivot pin and allows the pin and lever to come out of the pump and drop into the oil pan. This can occur immediately or after several hundred miles. This type of failure is not covered by warranty.
To ensure that the cam is at low position, it is necessary to use a mirror and a remote starter switch. Observe the cam through the mounting port and bump the engine around until a one (1) inch wide machine surface is observed. This is low position of the cam. Now complete normal fuel pump installation.
9502CA
1991
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #10 of 16 (permalink) Old 04-30-2009, 08:23 PM
Rockauto.com has AC/Delco's on closeout sale for $19.95 plus about $9.00 shipping. I got one and it worked good.
flyingj1000 is offline
post #11 of 16 (permalink) Old 04-30-2009, 10:26 PM
Bill1013's Avatar
As far as I know those pumps cannot be rebuilt, you can't take them apart once put together, they are swedged together. Take that 150 pump back and get one of the 40 pumps, they will last a lifetime . If they could be rebuilt , they would ask for a core.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #12 of 16 (permalink) Old 05-03-2009, 01:16 PM Thread Starter
Steve250's Avatar
the $150 pump was the wrong one... the guy on the phone didn't know what he was talking about. We got one from napa for $33 and put it in yesterday, it works nicely now. We also replaced the tranny cooler. Now all we need to do is drop the tank and and fix the pickup valve so we don't get stranded in the middle of the woods having ran out of fuel with half a tank of fuel still there!
Steve250 is offline
post #13 of 16 (permalink) Old 12-06-2012, 11:41 AM
For what its worth I bought and Air Dog II 165 last year for my 2005 6.0. I was a tough choice with many here on the forum not flattering to Air Dog's quality.
After less than 8,000 miles the electric motor on the Air Dog pump went out. I called Air Dog as it had a lifetime warrantee. They "couldn't find" the warrantee card I sent so I faxed them my reciept from Sinister Diesel for proof of purchase on the unit.
I was told that a receipt was not good enough and they charged me $218 for a new electric motor for the Lift Pump. I'll send in the warantee card on this one "Return Receipt Requested".
I would advise anyone purchasing an Air Dog Lift Pump to send in the card, and then CALL Air Dog and make sure they got it, get the persons name you talk to and the date of the call... The Air Dog works great...until it doesn't work, and then in my case their not all that receptive to customer satisfaction.
I don't know if the Air Dog is any better or worse than other Lift Pumps. I bought mine because of the Lifetime Warantee and I should have practiced CYA better and got confirmation of their reciept of my warantee card. Oh well, be careful..
BYT the Sinister sold me my Air Dog II #165 for $662.00 but I bought over $3000 worth of "get the 6.0 back on the road" parts. Good Company ease to work with when I emailed them about the problem I was having the spoke to Air Dog on my behalf. Air Dog was not receptive. Sinister even though it was no fault of theirs sent me a $100.00 gift certificate because it was a product I purchased through them... now that is customer service. Big difference in companies out there. Businesses forget that just because your on top today, doesn't mean you'll stay there if your unhelpful to your customers.
Thorn11acr is offline
post #14 of 16 (permalink) Old 12-13-2012, 09:36 PM
chuckster57's Avatar
Originally Posted by billlangy View Post
Should you also replace olives on the steel line when you replace lift pump?
If you can still get a seal without having to smash the olives, then I would re-use them.
Answered on my smart phone
Train Horns:
PM please not visitor message
chuckster57 is offline
post #15 of 16 (permalink) Old 12-13-2012, 09:45 PM
I didn't replace mine 4 years ago when I changed my lift pump. I started the truck and looked at the fittings. If it was gonna leak, it would have then. Still golden.
Train Horns:
