how to take off a serpentine belt - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 02-14-2006, 09:47 PM Thread Starter
My Photos: (14)
I'm wondering how this is done on my truck. The belt i have is squeaking up a storm and im gonna put on a new one. Also i cant find my Haynes Diesel manual. Its funny right when i need it, it gets up and walks away. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
2000 F-350 Super Cab,Long Box,4x4,7.3L PSD, Bully Dog Chip,6 sp. LEVER ACTION, Camper Pkg.,200k,Lariat, Clearance lights, White on top,Gold on bottom,Gold interior. 285/75/16 BFG's, Dieselsite.com 203* T-stat, alum. T-stat neck and coolant filter kit with Fleetguard WF2077 filter added.
1993 F-250 Reg. Cab 4x4. XLT. 7.3L IDI, E4OD, 4.10 rear, Fleetguard WF2077 coolant filter. Born: 9/92, 163k, Lumbar bench with armrest. White on top, blue in middle, white on bottom. Clearance lights,DeeZee diamond plate running boards to back of cab. True dual exhausts with glasspacks and 4" stainless tips. Pretty well stock except for Pioneer CD player.
rossman is offline
post #2 of 10 (permalink) Old 02-14-2006, 10:17 PM
rawpower's Avatar
Re: how to take off a serpentine belt
Hey im a senior in HS too...
Anyways, look towards the very center of your engine as if you were looking at it from the front. there is a tensioning pully that has a coil spring behind it that is about 3/32" thick with a 2" diameter. On the front of the pulley should be a 14mm bolt. This bolt does not loosen.
What you do is you put the wrench on it and use that as a leverage arm to compress that spring and it lets up on the belt giving you a little slack. Use your other hand to pull the belt off at any one of the pullies.
1993 Ford F350 7.3L Turbo Diesel ZF S5-42, Divorced TS NP205, OEM locker/welded 2.5 ton Rockwells, 46" Michelin XML's, and some stuff too.
rawpower is offline
post #3 of 10 (permalink) Old 02-14-2006, 10:33 PM
The bolt DOES loosen, it's just left-hand (reverse) threaded. On my 7.3 van it's 15mm. The tensioner is quite strong, I use a long breaker bar and socket to get it backed off enough to work the belt on and off.
The easiest way to work the belt is to take off at the tensioner first, and put back on at the tensioner last. Make sure you have a good socket and a nice long breaker bar on the bolt. Otherwise getting the belt on is very difficult.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #4 of 10 (permalink) Old 02-14-2006, 11:28 PM
cdnsarguy's Avatar
My Photos: (109)
Rossman.........when you get the belt off, locate about 1/2 the distance of full travel of the tensioner and attempt to check the tensioner for worn parts by trying to wiggle it in and out on the main bolt. See my gallery pic for bolt head sizes on the tensioner and pulleys.
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #5 of 10 (permalink) Old 02-15-2006, 07:56 AM Thread Starter
My Photos: (14)
How do about fixing that if its worn out? Or what i should say is it a simple change out?
rossman is offline
post #6 of 10 (permalink) Old 02-15-2006, 08:16 PM
yes its simple to change out yuo would just unbolt the tensioner assembly from the front of the block
Aric
96 F-350 4x4 regularcab dually 5spd 4.10LS
DIY open air intake hypermax dp 4" exhaust DIY exhaust brake
93 F-250 factory turbo 4x4 extended cab
4.10 5spd K&N filter ATS outler and down pipe 3in exhaust to twin 5" stacks tweaked wastegate turned up pump LUK clutch boost and pyro and much more to come
Ford makes it IH shakes it
Don't worry about the mule just load the wagon
93turbo'd_animal is offline
post #7 of 10 (permalink) Old 02-15-2006, 08:47 PM
2 points
1. A squeaky belt has many causes, a new belt may not cure the squeak.
2. If you have problems removing the old stretched out belt, how do you plan on putting the new tight belt on?
This task, while seeming simple, will/can cause many headaches.
Keep the old belt around so you can slip it back on, this way you can get back & forth to high school.
Best of Luck
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
post #8 of 10 (permalink) Old 02-15-2006, 10:27 PM Thread Starter
My Photos: (14)
I got it changed, it was just the belt-I mean i knew it was because i would shoot the belt with WD-40 and it would stop until it dried up. The belt i replaced wasnt that old, it was just squeaky for some reason.
rossman is offline
post #9 of 10 (permalink) Old 02-15-2006, 11:37 PM
rawpower's Avatar
May not have been the belt then... You could have been lubing something else with the WD-40 at hte same time as the belt rotated over that part. Unless the squeaking quit now.
rawpower is offline
post #10 of 10 (permalink) Old 02-16-2006, 11:03 AM Thread Starter
My Photos: (14)
Ya it has stopped squeaking now.
rossman is offline
