I was talking to a guy with a newer Dodge truck and he was saying this trans fluid,Hy-Gard from John Deere is been put in a lot of thier truck trans as it provides better lub and less wear then reg oil. Here is what he says,[If Randy is correct and he usually is, we don't need to change oil in the trans until we have 300K(!!!) on it. He says watch the oil color. If it turns brown then change it and find out what is wrong. Otherwise let it alone as long as everything is working properly. He did say that there will be NO scum like you get with ATF because the better lubrication stops clutch wear. He also said that even after 300K(!!!) the cleanliness of the trans will shock you].
I wonder if this stuff will work in our trucks, my friend says his truck shifts way firmer now with no slippige towing his 5th wheel and trans temps our down.
1994 XLT Turbo Diesel 4x4 auto extended cab, captain chairs, power windows, pdl, cc, IP and Turbo turned up and Pyro and Boost gauge installed
now thats interesting--does he have 300,000 on a trans with this in it the whole time????
this are automatic transmission he's talking about not manual, right?
exekiel
- 12/92 f350 jasper 7.3L 17k Torito
- Home made exekiel propane system, sweet
- Home made ram-air system
- 4.10 open, DRW
- zf5 trans (dextron and militec); 12" luk solid fly wheel and clutch set.
- exekiel coolant filter system (Fleet-guard filter and dca)
- ip runing with stanadyne every tank and Mels timed.
- Agnem manual tranns starting system :-)
- Hypermax turbocharger system YES Finally. Turned up a la Travis.
crew cab/ wood interiors/ 800w cd player. Sweet ;-)
2 new diamond headlights
4 100w flash lights and 2 withe fog lights more pics BOOB Man
this oil is a gear lube/hydraulic oil I would be a little scared to run it in an auto as its a little thicker then ATF also it is brown to start with [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
I worked at John Deer around 85 86 and we had a fluid for the tractors that exceded the ratings of dextron and type
F atf at the time. I used it in my truck when I changed fluid and run it over 200,000 before any problems, this was in a dodge with a 747 tranny. this oil was a lighter red color that atf
1994 F350 crew cab Dually 2 Wheel Drive 7.3 IDI, E4OD,factory turbo. just purchased april 2003, did rebuild ( rings and bearings )may 2003, Ready to start adding extras!!!
I work for John Deere now and have for 20+ years. The old fluid that was red in color was called Hydrostatic Fluid and was very similar to ATF. What John Deere now has is called Low Viscosity Hy Gard. It is still a hydraulic fluid but is only a 33 viscosity where the normal Hy Gard is 59 viscosity. They use it in place of Hydrostatic Fluid, in power steering units and hydraulic systems, especially hydrostatic drive systems. "Low-Viscosity HY-Gard replaces the John Deere All-Weather Hydrostatic Fluid and should be used as a direct replacement for all applications recommending hydrostatic fluid."
Not a definite answer, but I have used hydrostatic fluid as ATF and P/S fluid and never had any problems.
'91 F-250, 4X4, 7.3 w/ZF 5 spd. Old farm truck I am trying to resurrect into a better life. Not much to look at but is improving.
Agree with rbdutton on the fluid as for if it works I only have handshakers but I was just stating the difference in weight would worry me [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
