Hy -Gard Trans Fluid,John Deere - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 04-29-2005, 07:03 PM Thread Starter
I was talking to a guy with a newer Dodge truck and he was saying this trans fluid,Hy-Gard from John Deere is been put in a lot of thier truck trans as it provides better lub and less wear then reg oil. Here is what he says,[If Randy is correct and he usually is, we don't need to change oil in the trans until we have 300K(!!!) on it. He says watch the oil color. If it turns brown then change it and find out what is wrong. Otherwise let it alone as long as everything is working properly. He did say that there will be NO scum like you get with ATF because the better lubrication stops clutch wear. He also said that even after 300K(!!!) the cleanliness of the trans will shock you].
I wonder if this stuff will work in our trucks, my friend says his truck shifts way firmer now with no slippige towing his 5th wheel and trans temps our down.
1994 XLT Turbo Diesel 4x4 auto extended cab, captain chairs, power windows, pdl, cc, IP and Turbo turned up and Pyro and Boost gauge installed
skimoe is offline
post #2 of 7 (permalink) Old 04-29-2005, 10:30 PM
Re: Hy -Gard Trans Fluid,John Deere
now thats interesting--does he have 300,000 on a trans with this in it the whole time????
94_turbo is offline
post #3 of 7 (permalink) Old 04-29-2005, 10:43 PM
My Photos: (24)
this are automatic transmission he's talking about not manual, right?
exekiel
Was -
12/92 f350 jasper 7.3L
Is
12/92 f350 - 4.10 open, DRW CC with 5.9l CTD BANKS IC.
Getrag 360
- exekiel
system (Fleet-guard filter and dca)
- Agnem starting system :-)
BOOB Man
exekiel69 is offline
post #4 of 7 (permalink) Old 04-29-2005, 11:48 PM
this oil is a gear lube/hydraulic oil I would be a little scared to run it in an auto as its a little thicker then ATF also it is brown to start with [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Aric
96 F-350 4x4 regularcab dually 5spd 4.10LS
DIY open air intake hypermax dp 4" exhaust DIY exhaust brake
93 F-250 factory turbo 4x4 extended cab
4.10 5spd K&N filter ATS outler and down pipe 3in exhaust to twin 5" stacks tweaked wastegate turned up pump LUK clutch boost and pyro and much more to come
Ford makes it IH shakes it
Don't worry about the mule just load the wagon
93turbo'd_animal is offline
post #5 of 7 (permalink) Old 04-30-2005, 12:52 AM
I worked at John Deer around 85 86 and we had a fluid for the tractors that exceded the ratings of dextron and type
F atf at the time. I used it in my truck when I changed fluid and run it over 200,000 before any problems, this was in a dodge with a 747 tranny. this oil was a lighter red color that atf
1994 F350 crew cab Dually 2 Wheel Drive 7.3 IDI, E4OD,factory turbo. just purchased april 2003, did rebuild ( rings and bearings )may 2003, Ready to start adding extras!!!
comp486 is offline
post #6 of 7 (permalink) Old 04-30-2005, 12:39 PM
I work for John Deere now and have for 20+ years. The old fluid that was red in color was called Hydrostatic Fluid and was very similar to ATF. What John Deere now has is called Low Viscosity Hy Gard. It is still a hydraulic fluid but is only a 33 viscosity where the normal Hy Gard is 59 viscosity. They use it in place of Hydrostatic Fluid, in power steering units and hydraulic systems, especially hydrostatic drive systems. "Low-Viscosity HY-Gard replaces the John Deere All-Weather Hydrostatic Fluid and should be used as a direct replacement for all applications recommending hydrostatic fluid."
Not a definite answer, but I have used hydrostatic fluid as ATF and P/S fluid and never had any problems.
'91 F-250, 4X4, 7.3 w/ZF 5 spd. Old farm truck I am trying to resurrect into a better life. Not much to look at but is improving.
rbdutton is offline
post #7 of 7 (permalink) Old 04-30-2005, 08:24 PM
Agree with rbdutton on the fluid as for if it works I only have handshakers but I was just stating the difference in weight would worry me [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Aric
