With the weird hiss noise, affected by moving the t-case shifter; and the dried goo all over the outside of the t-case...I'm thinking I need a new T-case. Hoping it will also solve the driveline vibration problem at 60-65mph. U-joints didn't do it.
Anyone on the west coast with a cheap known-good 1356 that'll bolt into a 1991 5-spd, let me know.
While I'm at it, I'm also looking for a nice seat to replace this torn-up original 1991.
Hopefully one of the slightly newer super-comfy ones... [img]/ubbthreads/images/graemlins/grin.gif[/img]
One of us probably knows someone who's going up or down I-5 and would like some gas-money...so maybe we can avoid the shipping problem...
My other diesel is a...
Hydra 35-ton Excavator, 6V71T; Isuzu C201 genset;
'71 VanPelt Pumper, Cummins 855 Turbo
There used to be a link here, to some useful IDI-diesel tech info; but it was chopped out by others, in a vain attempt to repress the very essence of the internet: linking!
sigh...
Re: I guess I need a 1356 T-case, and a Nice Seat...
Richard
I'm tryin to think what could make that "hiss" sound, but can't figure it out.
My 1345 blew a crap a couple weeks ago. I thought the engine was misfiring, but it was the t-case poppping in/out of gear. It didn't happen when I put it in 4x4 low, but in high range, and got progressively worse over about 5 days till it wouldn't move at all anymore.
I pulled it and put in the guts from another one I had here, and it works fine, but now it too has a slight, but noticeable and irritating vibration at about 60mph.
They're not complicated inside, just a bit of a pain to pull and be without the unit for a couple days...
Might be worth yanking it and having a look inside the thing?
thanks for the notes Zigg.
It's pretty much a 'hiss' while driving along, but when I put a bit of forward pressure on the T-case shifter, it starts getting a more 'metallic' sound to it. Not a very clear description, I know...
I guess I mean that it starts to sound more like metal on metal, with that forward pressure. And pulling back on it a bit seems to make the hiss go away, or at least diminish.
What's the diff. between a 1345 and 1356 ??
Are they bolt-in compatible?
Are auto/stick t-cases identical?
Is there an interchange problem with putting an older t-case into a newer truck like a 91 ? I can't remember when the speedo thing changed... '92? 94?
What I'm getting at is, will ANY 1345/1356 I can get my hands on bolt right in? Or do I have to pay attention to year, tranny, etc.. ??
sigh...
ps: Zigg, weren't you chasing a vibration problem a couple years ago? Where you swapped everything under the sun and still couldn't find it, and it turned out to be the t-case?
sigh...
d9d, I think that they have different tail shaft assemblies and a different type of yoke. But they can be mixed and matched if you have some mech aptitude. Whoever swapped out mine forgot to put in a speedo drive gear and I had to grind a dimple into the output shaft for the gear spring-loaded ball to rest in. My truck was originally a 6.9 w/T-19 w/1345 and P.O swapped in a 7.3 w/E4OD w/1356. It has been a real nitemare trying to get it all figured out. Now I know why he sold it sooooo cheap. $1000.00 She seems happy now, but the test is coming in June/July...trip to Texas/Oklahoma pulling 29' 5th wheel [img]/ubbthreads/images/graemlins/vulnerable.gif[/img]. [img]/ubbthreads/images/graemlins/crazy.gif[/img]Baja
Is the 1356 stonger than the NP208? Most of the Fords I've owned had the NP TC's, but it seems all the diesel's (and the 460 parts truck I have) have the Borg Warner. Are they interchangable? NP to BW, or C6 to ZF5? Just curious....Got an NP in my Bronco and a spare in the garage, and a BW in the '91. Was wondering if the BW on the parts truck ('86--460--C6) might fit the '91.
Sorry to all the loyal 7.3 guys, but I traded my '91 7.3 in on a 2002 F250 Ex cab V10 4x4. SCT Xcalibrator2 with tunes by Powerplay Performance. 285/75/16 Toyo M/T's. Took a long time to get used to the ping-pop of a cooling catalytic converter...LOL.
'85 Bronco swapped up to a 302 4bbl from the 300 I6, NP435 4spd, NP208, 32x11.50x15 Radial RVT's, Soon to be 6.9 turbo powered.
86 F350 Cab&Chassis with a dump bed. 2wd 6.9 and 4 spd tranny. No mods to engine.
