Old 05-25-2005, 01:59 PM   #1 (permalink)
My Photos: (14)
I have a theory,
But I need all of your help to prove/dis-prove.
Please list the info below based on your truck running 2,000 RPM flat ground, no load, in your highest gear (freeway driving).
I need people to list:
Turbo system on truck
EGT's
Boost
Old 71 '93,F350 Crewcab, 7.3IDI with Hypermax non-Wastegated Turbo, 5 Speed, 4" Fabtech Lift, Filter Engineering Coolant Filter, 4" Straight pipe.
TurboYT is offline
Old 05-25-2005, 02:00 PM   #2 (permalink)
My Photos: (14)
Re: I have a theory,
Turbo system on truck = Hypermax
EGT's = 350*
Boost = 0 psi
TurboYT is offline
Old 05-27-2005, 08:45 AM   #3 (permalink)
My Photos: (20)
Hypermax
no boost
about 350 - 375 degrees
Early 99 F350 CC Dually 6 speed - just acquired with only 290,000 on the odometer... Build date of 11/98.
'91 F250 standard cab, 3 E4OD's in first 100k, Hypermax turbo, 99 powerstroke intercooler, 6 yes 6 speed ZF tranny installed at 100k miles!!, '99 E-350 ambulance disc brake, limited slip, 4.10 rear end
1983 Ford Ranger Diesel - 2.2l Mazda engine, custom built 5 speed using RX-7 parts, custom built ex manifold to add a variable nozzle turbo off a Mercedes, homebuilt 2 tank WVO system
1946 Dodge COE 1.5 ton in process of restoring and repowering with Detroit 4-53 turbo and Road Ranger 610.
My shop
jaybee is offline
Old 05-27-2005, 10:38 AM   #4 (permalink)
My Photos: (13)
2000 Rpms would be about 1-2psi, 350-400*EGT, but that is only about 55mph, so I am not pushing a whole lot of wind resistance. Why the question Turbo? Scotty
Semper Fi
Scott Beretz
2006 Dodge Megacab 4x4, Cummins, 6 Speed, Airbags, Quadzilla Commander, XZillaraider 2, 285/75R17 Toyo OC AT's
Pulls a: 3814SS Keystone Raptor Toyhauler w/Quads
beretzs is offline
Old 06-16-2005, 11:51 AM   #5 (permalink)
My Photos: (14)
I was trying to prove the point that non waste-gated runs less egt's.
TurboYT is offline
Old 06-16-2005, 04:40 PM   #6 (permalink)
My Photos: (13)
Oh, Okay. Sounds like you a true story. Scotty
Semper Fi
Scott Beretz
beretzs is offline
Old 06-16-2005, 07:07 PM   #7 (permalink)
425 degrees
2 lbs of boost
ATS Factory with ATS upgrade
My Truck - 1994 F-350 Crewcab 7.3 Factory Turbo
ATS upgraded Turbo Exhaust Housing, 3" Exhaust Outlet Housing and 3" downpipe, 3.5 the rest of the way back.
DPS Stage 1 Injectors
LGF Propane Injection
Pyro,Boost,water temp,trans temp gauges
K&N Filter
Wife's ride- Red, 2003 Excurision, Eddie Bauer, 6.0l 4x4, 63,000 Miles, Bone Stock
31' Salem LE Travel Trailer
My Pics
bsays is offline
Old 06-16-2005, 08:55 PM   #8 (permalink)
My Photos: (24)
hypermax
350 or less
not sure but 1 psi
Exekiel.
- 12/92 f350 jasper 7.3L 17k Torito
- Home made exekiel propane system, sweet
- Home made ram-air system
- 4.10 open, DRW
- zf5 trans (dextron and militec); 12" luk solid fly wheel and clutch set.
- exekiel coolant filter system (Fleet-guard filter and dca)
- ip runing with stanadyne every tank and Mels timed.
- Agnem manual tranns starting system :-)
- Hypermax turbocharger system YES Finally. Turned up a la Travis.
crew cab/ wood interiors/ 800w cd player. Sweet ;-)
2 new diamond headlights
4 100w flash lights and 2 withe fog lights
more pics
BOOB Man
soon..
- paint job.
exekiel69 is offline
Old 06-17-2005, 05:44 AM   #9 (permalink)
My Photos: (33)
Hypermax pulse 1.0 turbine a/r
350 F
Less than 2psi (gauge starts at 2)
95" Extd Cab F250HD 4x4 DRW, /86"6.9 T19 GV o/d 3.73 axles, Hypermax Pulse turbo, intercooled / Modified Hypermax ram air induction, PowerShot 2000 LPG system "first design". Ride rites @ all 4 corners, Dana 50 mono Beam up front, Ford 10.5" in rear with 4 wheel disk brakes. Other Truck, 1983 IHC "S" with 14ton NoMar wrecker body, 30,000 GVW, 229"wb with a 6.9L IDI, Clark 5sp, 5.57 rinp&pinion, turbo charged and intercooled (with LPG soon).
Huff is offline
Old 06-17-2005, 07:58 AM   #10 (permalink)
bwc
CTS (Canadian Turbo System)
EGT @ 2000 rpm - 300 - 400 F
Boost - 0 - 2 psi
'91 F-250 XL SC, Schwitzer Blower, LWB, 4x4, LS 3.55's, ZF 5 spd, LUK Rep Set, Most
options except PW/PL, 85000 km, Leer 48" High Boy Cap, Westach
Pyro/Boost Gauges, Hour Meter, Racor water/fuel filter,
Wired for Camper & TT, Fumoto Drain Valve,
Michelin LTX's 235/85R16E A/S
Firestone Ride -Rite
Air Bags and Compressor.
bwc is offline
Old 06-17-2005, 09:38 AM   #11 (permalink)
Tubo =ATS WastGate
2PSI
425F
1990 F-350 Dually 4X4 CC Rebuilt Turbo and NEW 7.3L DAS engine, rebuilt rear diff, Reman E4OD Stage 1 injectors Stage 1 pump Baumann recal kit and TDC for E4OD dead trans again...
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
DSBlack is offline
Old 06-17-2005, 11:53 AM   #12 (permalink)
My Photos: (14)
Well so far seems like a true story.
TurboYT is offline
