1994 F350 IDI Turbo "K" shifts hard and won't lockup torque converter. OBDI code is 23, TPS. Where can I get the part and does anybody know a part number on it?
Just a follow up. New TPS and it shifts "better"...still won't lock the torque converter and the OD light still flashes, but it drives ok for local stuff. Oh, and the cruise control now works. Other issues, but making headway.
Sure wish people would put there truck in there signature and check mark to leave it there. Don't have to go back to there 1st post to see what you have.
Your 94 has a VSS (Variable Speed Sensor) mounted on top of the rear axle. One bolt holds it in, pull it out and check for metal shavings, check connector for corrosion. An intermittent signal from the Tach sensor mounted on the IP gear housing, do the same there.
I'll need to get it started again first. Changed water separator filter and having trouble getting fuel all the way to the injectors. :/
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
