IDI=gasser?? - Diesel Forum - TheDieselStop.com
Old 11-12-2009, 08:39 PM   #1 (permalink)
oneuponu's Avatar
IDI=gasser??
hey guys , can someone come up with a way to make the old IDI 7.3's stop sounding like a gaser? at idle they sound like a stroke, but when in high RPM's, they sound like they have a 351! anyone got any tip or mechanics you can do to make her sound as close to a stroke as possible??
oneuponu is offline
Old 11-12-2009, 08:48 PM   #2 (permalink)
NH2112's Avatar
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
It's the nature of the beast with an indirect injected engine - they're quieter than direct injection.
Phil
1988 F350, NA 7.3l, 5-speed, crew cab, 4.10 SRW. Miles: over 450K. Being taken off the road within the next month or so to deal with advanced rust. May just do a resto/rebuild to better my bodywork & paint skills.
NH2112 is offline
Old 11-12-2009, 08:51 PM   #3 (permalink)
oneuponu's Avatar
like this video , i mean once it gets high enough in the RPM's , you cant even tell its a frickin diesel!!, no one out there has a solution for this??
YouTube - 94 7.3 turbo Diesel Truck, straight pipe
oneuponu is offline
Old 11-12-2009, 09:31 PM   #4 (permalink)
It's supposed to sound that way, If you advance the timing a whole bunch it'll get noisier but will eventually wreck the engine.
Evel486 is offline
Old 11-12-2009, 09:37 PM   #5 (permalink)
oneuponu's Avatar
i dont want it noisier, just dont want that old 351 sound, i want a POWERSTROKE sound, but i mean front the front of the truck when u revb it up it sounds normaly like a stroke, but quiter. But when u move to the side or back it just sounds like nowhere near a diesel, so no one has any ideas about changing around exhaust or sumthin?? or anything??
oneuponu is offline
Old 11-12-2009, 09:44 PM   #6 (permalink)
repomanian's Avatar
I wonder if ftermarket headers (if available) to a custom x-pipe to aftermarket muffler really might smooth of the sound and make it less poppy... This was the case on my 302 stang, which is a different beast, but I'm curious if it would work by any chance. Ideas?
1994 F350 7.3 IDI N/A...220k miles. 6" Pro Comp lift, 38" Super Swampers. Crew Cab, full bed, E40D, stock everything else, for now!!
repomanian is offline
Old 11-12-2009, 10:00 PM   #7 (permalink)
oneuponu's Avatar
to much money, to much time, idk if i put stacks will that help?? or maybe chip it, cold air kit, idk maybe even injectors....$$
oneuponu is offline
Old 11-12-2009, 10:30 PM   #8 (permalink)
chuckster57's Avatar
Only chip would be the ones on the seat smothered with nacho sauce. My truck sounds like a diesel through the entire RPM range. May be my age but I used to run a 460 with headman headers and dual 2 1/2' out the back. It would set off car alarms @ 1500 RPM...I like running as close to stealth as possible now...the radio sounds better and the speakers will probably not need replacing.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline
Old 11-12-2009, 11:53 PM   #9 (permalink)
repomanian's Avatar
as far as answering your question, i think my idea is a decent one... And of course it would cost money to do. You even asked if you could do something with the exhaust and I think i hit it pretty close. Stacks won't help... That's just moving the sound you hate so much into the bed. Air intake? that won't do a think to change the sound... Can't chIp the IDI, and injectors just give the engine fuel, it won't change the way it sounds at all. That's like saying a fuel pump will change the sound at all... Not gonna happen. You have to mess with exhaust gasses, ie turbo, x-pipe, mufflers, headers, etc.
Old 11-13-2009, 01:45 AM   #10 (permalink)
rotaryboots's Avatar
Send a message via MSN to rotaryboots
Its an IDI not a DI (powerstroke) Thats just what its going to sound like. The most advanced piece of electric technology under that hood its probably the alternator hence the beauty of these engines cause there's not much to go wrong. Sure you can make it sound like a powerstroke but you're going to need to be running over 20psi of boost like the powerstrokes do. Doing that isn't easily reliably accomplished without adding a turbo setup capable of over 20 psi of boost, fire-ringing the heads, widening the pre-chambers, getting bigger injectors and a larger IP like a Moose pump or something, and then keeping it cool by adding an intercooler, and larger exhaust and in conclusion it would be cheaper to buy something like a low milage 2007 Powerstroke than making this engine perform up there and "sound" like a powerstroke. Then again, its a truck, they tow, haul, and do work. Ford didn't really put "sound" on the drawing board This engine will however outlast it's truck's body and short of basic maintenance, run and run and run and...
'90 7.3 IDI F350 4x4 Custom, ext cab, E4OD w/ tow package, 4.10 Dana LSD rear, 94' ATS turbo kit w/ 99' PSD wastegated charger set at ~20psi max, copper firering head, studs, turbo IDI block, mild head work, Delta Cam, Moose pump, turbo injectors, 6.0 PSD intercooler, propane injection, 3in exhaust. Almost 300 and 500. (added 2 more flats than previously) 296hp, 487tq (6/4/11)
'03 7.3ltr Powerstroke F350 4x4 4dr. SCT Livewire, ATS exhaust, rebuilt HD trans, 6.0 trans cooler, fuel mods, AFE intake, Garrett gtp38r ball bearing turbo; glad its not a troublesome 6.0
rotaryboots is offline
Old 11-13-2009, 09:32 PM   #11 (permalink)
88beast's Avatar
glasspacks will give a gasser sound
proper timing will give a psd knock at idle
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 11-14-2009, 06:57 AM   #12 (permalink)
An IDI will never sound like a powerstroke ever. If you want a loud diesel, put an older 12 valve cummins under the hood. They are not computer controlled, and you get a turbo. They are non computer controlled like the engine you have also. These conversions are getting more common these days, and I am sure there is a fair amount of info out there to get the job done. Only reason I don't say put a powerstroke is you stay computer-less with the cummins, and you get all the racket you want. Me personally, I like the fact my IDI is nice and quiet on the highway, but I guess that comes with age, at least it did for me.
1992 F350 Crew Cab 4x4 7.3l IDI E4OD No Turbo
1993 F350 Crew Cab 4x4 7.3l IDI E4OD No Turbo
1990 F250 Super Cab 2x4 7.3l IDI E4OD Utility bed
1987 E250 Quadravan 4x4 6.9 IDI C6 Banks Turbo, Gearvendor, and U.S. Gear Exhaust Brake
DragRag is offline
Old 11-14-2009, 10:59 AM   #13 (permalink)
oneuponu's Avatar
Well besides that, i have a bigger garrett turbo, and the guy i bought the truck from said that you can turn that turbo up somehow?? so can anyone explain how to do this?? o and is it okay if i turn the injector/fuel pump up a little bit?
oneuponu is offline
Old 11-14-2009, 09:49 PM   #14 (permalink)
I dunno, I really like the sound of the IDI diesel. At idle it has that classic diesel growl and at full throttle it sounds like a badass big block American V8. Correct me if I'm wrong but I'd imagine that a new exhaust system and a chip would make that sound even more prominent.
My beasts:
1989 F350 XL Jasper 7.3 IDI non-turbo. Auto, RWD, dually, 12ft box, ugly as hell! We call it Big Ugly.
1999 F250 XL 5.4 Triton. Auto, 4x4, my "pretty" truck.
JH3Rob is offline
Old 11-14-2009, 10:46 PM   #15 (permalink)
Your wrong about the chip...Doesn't make a bit of difference. I have a turbo and 3" unrestricted exhaust. It doesn't sound ANY thing like my old '86 with it's 460, Headman headers and dual 2 1/2 unrestricted exhaust.
I like the way my truck sounds and the exhaust level was fine for hours at a time this summer on our road trip. In 2000 I took the gasser to Missouri and back and after 4 hrs. my ears were ringing.
