My 1988 F-350 ignition switch has a position CCW of LOCK. Is this an accessory key position? If so, what accessories should be energized at this position?
Thanks --Jim Jim Jim
PS special thx to RWF350 for sending fuel system electrical details.
Jim Jim Jim
-- 1988 F-350 (type F379) 7.3 NA diesel ZF5 4.10 DRW 11' service body
-- 1981 Toyota pickup 2.2L diesel 5-speed LB
-- 1980 Mercedes 300SD 3.0L turbo AT
Maybe I don't either - perhaps my ignition switch is just BROKEN, allowing it to turn CCW past LOCK. I have never seen an owner's manual for my truck, so that's why I'm asking about this here.
So is there an ACC position CCW from LOCK?
Regards,
Jim Jim Jim
If it won't turn back to the ACC spot, the tumbler is worn. I took mine out, lightly greased it, and put back. Works much better, still needs a new tumbler though.
In the acc position: radio and windows work, I think the wipers and gauges work as well.
Deceased--1990 F350 2wd DRW Super Cab E4OD 7.3l IDI
Gooseneck hitch, Flowmaster (single inlet/dual out), 60 gal tank/toolbox/bedrails/headache rack (custom built, welded together as 1 unit), 3 gauge pillar pod w/glowshift gauges, oil, water temp, trans temp
Never ask "What else can go wrong?" cause something will.
The proper ignition switch positions are ACC-Lock-Off-Run-Start. So yes, the ACC is CCW from the Lock position (where you can take your key out). The ACC will power the radio and power windows if you have them. The ignition switch itself is actually the same as used on Ford's passenger cars of that era, only the linkage between the lock tumbler (where you put the key in) and the actual ignition switch (way down on the steering column) leaves a lot to be desired... which is the source of many problems with missing IGN switch positions.
Is there supposed ti be a little button on the bttom of the steering column that you have to push to rotate it to ACC? There is a little square hole on the bottom side of the column under the IGN. Is this what is supposed to be there?
1989 F-250 4X4 C-6 7.3 IDI, 4.10 SRW, Cobra 148GTL, 4ft bed mounted whips, 12" Powerbass sub, 600W Powerbass amp, Sony Headunit, GPC override(thanks M.L.S.C), Factory Ford aluminum rims from OBS PSD, 4" exhaust, no soupbowl, B&M shift kit
So I should just be able to rotate CCW to ACC? No buttons need to be pressed or anything? Sounds like my IGN. tumbler needs a replacin...
Your ign tumbler only rotates. The end of it has two "ears" that fit into a slot to move electrical contacts. If your not having a problem turning the key then the tumbler assembly is good.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
Mine has a spring loaded ball in the tumbler that stops it at a detent for "off". It had worn a groove in the "outer" tumbler case that the ball could not over come to go into acc position. I took the tumbler out and I put a light dab of silicone grease in the tumbler where the ball is at with a q-tip. Works pretty good right now.
