Ignition Switch ACC position? - Page 2 - Diesel Forum - TheDieselStop.com
Old 11-23-2009, 07:21 PM   #16 (permalink)
StrokerSmoker7.3's Avatar
OK how do I go about taking the ign. out to grease this little ball?
1989 F-250 4X4 C-6 7.3 IDI, 4.10 SRW, Cobra 148GTL, 4ft bed mounted whips, 12" Powerbass sub, 600W Powerbass amp, Sony Headunit, GPC override(thanks M.L.S.C), Factory Ford aluminum rims from OBS PSD, 4" exhaust, no soupbowl, B&M shift kit
1997 F-350 4X4 E4OD 7.3 Powerstroke, 3.55 SRW. 3"DP to 4" exhaust, TS performance 6pos. chip, Quadzilla Recon XGT, DIY Tymar style intake, Atwood fiberglass cap
StrokerSmoker7.3 is offline
Old 11-23-2009, 08:35 PM   #17 (permalink)
RWF350's Avatar
Turn the key to the run position, push a small punch/screwdriver in the hole under the tumbler in the steering column. Pull the tumbler out. Then push some grease in to the tumbler from the key end. The tumbler itself does not acually come apart.
2007 Chevy 2500HD 4WD Ext Cab (late model) 6.0L (gas) 6speed auto
Deceased--1990 F350 2wd DRW Super Cab E4OD 7.3l IDI
Gooseneck hitch, Flowmaster (single inlet/dual out), 60 gal tank/toolbox/bedrails/headache rack (custom built, welded together as 1 unit), 3 gauge pillar pod w/glowshift gauges, oil, water temp, trans temp
Never ask "What else can go wrong?" cause something will.
RWF350 is offline
Old 11-24-2009, 08:14 PM   #18 (permalink)
The little square whole? Then put grease in the actual key slot then put the key in to push it down? Whats the best type of grease?
Old 11-24-2009, 08:40 PM   #19 (permalink)
RWF350's Avatar
The hole is just above the hazard switch, below the tumbler. Once you get it out, you'll see how it rotates inside of itself. I pushed grease in behind the chrome ears between the inner and out parts of the tumbler. You'll see how the detent works, just lube it enough so it'll roll back past it. I've used vaseline on one truck, dielectic grease in another. PM me, I'll send you an exploded view of the column. Let me know wether or not you have tilt.
RWF350 is offline
Old 11-25-2009, 08:13 AM   #20 (permalink)
PM sent. thanks!
Old 12-25-2009, 07:02 PM   #21 (permalink)
Wipers also work @ ACC, but not the instruments.
I fixed my NO ACC problem by adjusting the ignition switch position on the steering column. The ignition switch is mounted to the column under the instrument panel and connected to the key cylinder with a rod that runs down the top of the column. Ignition switch needed to be moved slightly closer to the key cylinder.
Regards,
Jim Jim Jim
-- 1988 F-350 (type F379) 7.3 NA diesel ZF5 4.10 DRW 11' service body
-- 1981 Toyota pickup 2.2L diesel 5-speed LB
-- 1980 Mercedes 300SD 3.0L turbo AT
jim x 3 is offline
Old 12-27-2009, 02:56 PM   #22 (permalink)
RWF350's Avatar
Ah, somebody replaced it and didn't get it lined up right.
RWF350 is offline
