Old 03-08-2007, 07:18 PM   #1 (permalink)
Ignition switch problem 1994 F250
When starting the truck today the ignition switch had an odd feel when turning the key . The glow plugs worked, the truck started, the gauges worked but the odometer, speedometer, did not, the brake, oil, water in fuel warning lights on the right side of the dash were on , and the OD light was flashing . I restarted the vehicle and had no more problems . I presume that the ignition switch is failing . Which part is failing and what is the repair solution ? Does to column have to be disassembled to repair it ? - Thanks
1994 F250 7.3 IDI E4OD
rkpatt is offline
Old 03-09-2007, 01:27 AM   #2 (permalink)
My Photos: (17)
Re: Ingnition switch problem 1994 F250
Sounds like you need a new key cylinder. Available at auto parts store for about $10.00. There is a small hole under the cylinder, turn key to "RUN" position and use a allen wrench to press the button in the hole. Pull cylinder out. OkieGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 03-09-2007, 07:50 AM   #3 (permalink)
Re: Ignition switch problem 1994 F250
Okie - I changed the cylinder out with one from Autozone a little over a year ago . I guess that it could be bad. However the symptoms of getting part of the system working made me think that the problem was in the electrical part of the ignition switch assembly(instead of the cylinder ) Anyone have a good diagram they can post or email
? - Thanks
rkpatt is offline
Old 03-09-2007, 12:51 PM   #4 (permalink)
cdnsarguy's Avatar
My Photos: (66)
I have a GP controller test PM me an email addy and I will send it when I get back from the shop. Check your ground wire on the GP controller.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 03-10-2007, 03:04 AM   #5 (permalink)
My Photos: (17)
Pull the cylinder and spray the crap outta there. Stuff it with di-electric grease. OkieGringo
Old 03-10-2007, 01:20 PM   #6 (permalink)
Was the key hard to turn? I have run into a problem with the rack that operates the ignition switch on some of these trucks. I usually remove the column covers and use a spray grease on the linkage and this usually helps. The reson that the lights are acting up is that the linkage binds up and will not allow the ignition switch to fully return to the run position. Hope this helps!
94 F250 S/C 4x4 7.3 lt IDI factory turbo E4OD and 4.10 soon to be limited slip, bone stock with triple gauge pod on the a pillar
swervn69 is offline
